White Balence - Am I Missing Anything?
When I do a white balance correction in Vegas, I apply the Color Corrector to the clip on the time line that I want to correct. I then select the "Choose Complimentary Color" eyedropper for the High frequency colors. and click on an area in the clip that is the reference white. I then drag the circle that appears on the color wheel to the center of the wheel. Is that the correct white balance correction procedure or am I missing something?
Are you shooting in RAW?! If not, how do you want to do a white balance? The color corrector can only work on a certain color level but can not move everything into the right balance.
Axel |
What you did correctly was the reference white bit. And what you noticed was that the Hi-Wheel centre move away fro the centre. So what has happened, for example, if you were slightly too cool>bluish, then what VEgas did was make a 180 degree inverse of that to go towards the REDS and warmer whites. And THAT would have been the correction. DONE! What you then did was to force the correction BACK to the centre, thereby removing the correction. But, fair do's on your approach! Like it! Grazie |
Hmmm.....
I just watched the video quoted. I wouldn't do Mid-tones on the skin colour? I would do Mid-tones on a neutral grey. Correcting on a skin colour would, in my way of thinking skew away from the skin-tones itself. I don't understand why this was emphasised? But I am always willing to learn. Grazie |
