-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Error in DVD Architect (https://www.dvinfo.net/forum/what-happens-vegas/235283-error-dvd-architect.html)
Martin Wiosna May 13th, 2009 11:49 AM
1 Attachment(s)
I'm trying to burn a DVD for some reason I can't. It renders and it says its complete but nothing burns.
I save a screenshot of the error message, I'm thinking it might be my DVD burner (as im having issues burning CDs as well (thru Windows Media Player).
Edward Troxel May 14th, 2009 07:05 AM
Here's my suggestion:
PREPARE using DVD Architect which will create a folder containing the Video_TS and Audio_TS folders.
Now BURN the DVD using a DVD burning program such as Nero or Record Now or anything that will recognize those two folders and properly burn them as a DVD.
Fred Foronda February 23rd, 2010 12:52 PM
This is a similar issue I've gone through doing a dual layer dvd project. So there is nothing wrong with my icore 7, vista ultimate 64bit, LG burner, Pioneer BR burner yada yada yada computer that I built then. Its a DVDA problem whew....I feel relieved. Thanks everyone for a great fourm!!!!! an awsome resource tool!!!!!!
Noted that this post is almost a year ago. My Vegas 9 is still what it is out of the box. Will an update be a fix to this problem?
Fred Foronda February 24th, 2010 12:35 AM
I tried using Nero, failed. Using memorex DVD +R DL. It freezes during the write out. Is it the media I am using? I doubt its my burner, did single layer dvds before with no problems. PC is windows vista ultimate 64 bit, intel core 7 , 6gm mem
Randall Leong February 24th, 2010 01:27 AM
Fred,
It is the media that you're using. Memorex gets its DVD+R DL media from two companies: RiTEK (Taiwan) and Moser Baer (India). Neither company is renowned for its DL media (at least those DL media using those manufacturers' own codes and technology), and both companies' DL media have had major compatibility issues with even newer burners.
At one point Verbatim (one of only two manufacturers that are any good for DL media - the other being Falcon Tech in Dubai) used Moser Baer as a subcontractor (albeit using Mitsubishi's own media codes and technology). But the production of most Verbatim-branded DVD+R DL media has since reverted to the company's own plant in Singapore (with the exception of a few DL discs manufactured for Verbatim by CMC Magnetics in Taiwan using Mitsubishi codes and technology).
Also at one point TDK got its DVD+R DL media from CMC Magnetics using CMC's own codes and technology. But since TDK's media division was bought out by Imation (the parent company of Memorex), TDK-branded DVD+R DL media has been mostly RiTEK stuff.
As for the burners, not all DVD burners are equally competent at burning DVD+R DL media. In general, Pioneer burners perform best at writing to DL media; Lite-On burners and any other burners using MediaTek chipsets proved mediocre at best on DL. LG-branded burners are somewhere in between.
Fred Foronda February 24th, 2010 11:34 AM
Randall,
Thanks for sharing the info and clearing things up. I'll go back to the retail store and return the spindles I bought. For now since TDK single layers have been working well with my set up I'll just split the project into two disc. I also noticed on the manual that the LG burner came with listed suggested media to use and Memorex was not on the list.
