Capture to MPG not AVI??
vegas only allows me to capture analog via my canopus, but in AVI format.
I captured a 2 hour tape which created a 25gig file. Then I have to convert that (either in DVD Maker or re-rendered in Vegas) to make it into a usable mpeg2 file for putting onto a DVD. My question is this: Is there a simpler way to capture analog tapes without having to use a middle step of converting it to mpg for eventual use in mastering a DVD? I've tried to put the AVI directly in DVD Maker and it takes about as long to convert in there as it does in Vegas if I re-render. I've considered/tried the following: 1) Record directly to a DVD-RW and ripped that DVD into MPG format for use on my DVD Maker file. Quality is whatever the DVD recorder gives me (no control over bitrate, etc.) 2) Recorded directly to my PC via the Canopus, but captured as AVI in Sony's capture software. Then I have to convert the avi to MPG... which adds nearly as long as the realtime capture. (I have a brand new computer 1 week old with nothing else on it and it dualcore pentium 3gghz). 3) Find some kind of capture software that canopus is recognized as a DV device and will render it realtime as an mpg2. Also... what's the difference between mpg2 and mpg4 when it comes to creating a DVD in Sony's DVD Maker? |
DV-AVI (which is what you captured) is much easier to edit and use than any MPEG format. MPEG2 is a destination format. So you're really better off capturing and editing using the DV-AVI file and then doing a final render to MPEG2 for DVD.
missing my point
I'm not trying to create a movie or anything requiring vegas editing capabilities. I'm trying to simply copy old analog tape footage to a dvd with a menu.
In order to have a menu, I have to use DVD Maker. In order to use DVD maker, I have to either allow it to convert the AVI files or have them converted already. So, how do I avoid the lengthy delay of capturing to AVI and then having to re-render to MPG2 just to create a DVD with a menu? I know I can make a DVD without a menu simply using the DVD Recorder, but that's not my goal. |
For copying VHS to DVD I use VLC (for capture) and ManDVD (for simple titles and authoring) in Ubuntu Linux. Simple. Oh yes, and the capture card is an Hauppauge PVR150. (Which, incidentally, doesn't work under VISTA).
Unfortunately, I currently have no way of capturing from VHS on VISTA but at least the Linux/VLC/ManDVD option is all FREE! |
I'd go for option 1 (which I often do if I just need to dump a tape to DVD without editing). DVD recorders do have bitrate options. On the highest quality (called HQ on mine), a 60 minute DV tape fits on a single DVD-R. I can't tell the difference even on a true video monitor (as opposed to TV).
What do you suggest? |
I've seen several different brands of standalone DVD recorders (the ones with a built-in hard drive) that allow simple editing and the creation of a basic menu.
You could also record to DVD, use the MPEG2 files as source files for your menu-adding software and create a new DVD. The files will be untouched and you'll get the menu.
Personally, I'd probably still do it the same way - capture as DV and then create the DVD from the DV footage. However, you do have other methods available. If you do record onto a DVD, you can the use File - Import - DVD Camcorder Disc to pull that footage in. You should then be able to drag that footage straight to DVD Architect. |
| All times are GMT -6. The time now is 03:10 AM. |
