-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Editing SD and HD in one project (https://www.dvinfo.net/forum/what-happens-vegas/146533-editing-sd-hd-one-project.html)
Marius Boruch March 24th, 2009 04:29 PM
I have SD and HD files that I'd like to combine in one project. I have two video tracks - one for SD and other for HD files, but I'd like to edit and then render them to SD 4:3 fomat; if we had pan/crop button in video track that we could switch etire video track to 16:9 format that would be great and so easy. But we don't. Now I have to click every single HD file (100+ of them) manually to switch to 16:9. It is insane. Am I missing something; is there any other easy way to switch entire HD video track from 16:9 to 4:3??? It must be....
Marcus Martell March 24th, 2009 05:14 PM
I need 2 know the contrary: alot of sd mixed with a lot of hd to render in HDV. Hoping somebody will post settings.
Thx
Paul Kellett March 25th, 2009 02:52 AM
If you're not doing a multicam edit so still have seperate video tracks then do this
>crop the first clip to how you want it
>on that cropped clip right click
>copy
>right click again, select events to end, all clips on the track are now highlighted
>put mouse on a highlighted/uncropped clip
>right click
>paste event attributes
That'll do it.
Paul.
Marius Boruch March 25th, 2009 11:53 AM
thanks a lot
Marcus Martell March 25th, 2009 03:33 PM
Hey Paul so will this work for me 2?
thx
Paul Kellett March 25th, 2009 03:46 PM
thx
Should work, try it.
Paul.
Marcus Martell March 25th, 2009 03:52 PM
As soon as i will come back home next week,for sure i will!
Thank you 4 your advice
MM
Marcus Martell March 28th, 2009 10:17 AM
Hallo dear friend of mine,hoping not bother you with my question:
I put on the timeline my 85% of HD footage on the upper track,on the lower track i put the SD 4:3 footage;now i want to render in PAL DV §Widescreen ok?Is it correct to open my project with HD settings 1080 50i(Pal) if i want to render in pal dv wide (SD)?
What about the black lines (of the SD footage)that appear after i crop in 16:9?
The sd footage have it(cause 4:3),but the HD footage don't!Could you give me any suggestions?
thx
Paul Kellett March 28th, 2009 10:27 AM
Hi Marcus.
Project preferences should match most of your footage so yes, use the HD settings for project prefs.
Cropping SD footage into 16:9 shouldn't leave any black bars, the SD footage will have bars at the sides before you crop but not after, the SD should fill the screen after cropping.
On the SD footage, hit the pan and crop icon, the pan and crop window opens, at the top on the right, open the little drop down list, 16:9 should be there.
This video hlink below is SD and HD mixed together, no bars anywhere.
Mark & Jenna Highlights on Vimeo
Paul.
Marcus Martell March 28th, 2009 10:49 AM
Hey Paul, u were right!What about if i wanna use the 16/9 upper e lower black line?Should i use a black solid with media generator?
Another quest:I saw your video,verycool!Have you ever thought to use those plugins(Instant HD from Redgiant) to resize the SD footage to HD?
Last question about project settings in the mix of HD and SD: Full-resrend quality:Good
Motion Blur :gaussian
Deinterlace method: None
Let me know if u think they r right!
thx a lot,have a nice weekend
Paul Kellett March 28th, 2009 10:57 AM
16:9 black bars for what ?
Render settings, BEST for mpeg2/dvd.
Paul.
Marcus Martell March 28th, 2009 11:59 AM
Black bars 4 the cinelook;could somebody help me with the right term of them?
thx anyway
Paul Kellett March 28th, 2009 01:15 PM
21:9 aspect ratio.
Paul.
Marcus Martell March 28th, 2009 07:01 PM
Where can i find the 21:9 aspect?I went on the scroll of Pan & crop but nothing.
Thx a lot
