Colour managment in 2nd monitor
Does anyone use the colour management setting for the 2nd monitor ?
Are there any benefits ? If so then what settings do you use ? Paul. |
absolutely! set the display to studio RGB if you deliver on NTSC. otherwise, your luma values won't be properly displayed. I also activate color management and use a profile that is more representative of SMPTE.
Thanks Bill, i was hoping to hear from someone of your calibre.
I'm in the UK so it's pal for me, if that makes any difference. So i select colour management, then tick the studio RGB box, then what would be best to select from the drop down box ? I've tried a few and they do give different pictures so i want to make sure i use the correct one. Thanks Bill. Paul. |
Paul...
Studio RGB is the same for both NTSC and PAL, and is representative of a broadcast display system(TV). It sets the RGB bandwidth to 16-235. Deselecting studio RGB is representative of a computer display system. |
| All times are GMT -6. The time now is 03:17 PM. |
