-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Graphics card for HD (https://www.dvinfo.net/forum/what-happens-vegas/141071-graphics-card-hd.html)
Dale Guthormsen January 7th, 2009 10:26 AM
Is Using and I7 920 with 8 gigs adequate to run hd in vegas. Will be hdv from xlh1.
will a radeon hd 3450 be adequate as a graphics card?
Perrone Ford January 7th, 2009 11:10 AM
Vegas does not use the accelerator (GPU) on graphics cards, so get as much CPU and RAM as you can afford. Make sure you have fast drives too. RAID is always a good thing.
Jeff Harper January 7th, 2009 12:38 PM
Dale, I run that card, it is fine. But if you plan on using MB Looks with Vegas you would want an NVidia card for optimum performance. You would go to their website to see which cards are supported.
If you're sure you are NOT going to use MB Looks, than just as Perrone says it doesn't matter.
Perrone Ford January 7th, 2009 12:41 PM
Jeff,
Are you talking about MB Looks inside Vegas, or the Full Suite running outside of Vegas? I am about to buy a hot graphics card for my machine, and am wondering if I will get preview speed enhancement and MB Looks enhancement with the Vegas plug-in.
Jeff Harper January 7th, 2009 12:47 PM
Perrone, I don't know if the version that came with Vegas 7 is helped by cards or not, it might be....but I am talking about the MB Looks you buy from Red Giant. Apparently with the right card there can be a difference in performance. I do know that when using the trial of MB Looks I was told at one point my graphics card didn't support a feature, though I forget what feature that was.
There are people around here that would know the specifics better than I. I only use the freebie version.
