-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   LCD Monitor for Vegas - need one that good color reproduction - ideas? (https://www.dvinfo.net/forum/what-happens-vegas/141007-lcd-monitor-vegas-need-one-good-color-reproduction-ideas.html)
David Delaney January 6th, 2009 04:51 PM
I have been buying, testing and returning monitors lately. Using this site :LCD monitor test images
I have been experimenting to try and find the best monitor to use with Vegas. Right now I have a CRT and a LCD monitor. The CRT consistently out performs the LCD for contrast, colors and pure black/white. So, is it impossible to find a LCD that will perform like a CRT for use with NLE's? I know that cost is always an issue, but I wonder what other Professionals that use VEGAS are working with when it comes to 20-32 inch LCD's.
Laurence Scott January 7th, 2009 02:36 PM
I'm using (2) 24" Gateway FHD2401 monitors and I've been quite pleased with them. For the record though - I'm a semi-professional.
Jeff Harper January 7th, 2009 03:05 PM
AGN Professional - AGNPRO - Professional LCD Monitors - X-Series
Personally I use a 2405 FPW Dell alongside a JVC CRT broadcast monitor for color. Professional grade LCDs like the ones above cost thousands.
Jonathan Gentry January 7th, 2009 10:53 PM
Not sure if video editing is as critical as photo editing which is more of what I do, but if you want accurate colors you should go with the NEC LCD2460WUXI-SV. If you want a wide gammut which will show most of Adobe 98 color space go with the LCD2690WUXI-SV.
-Jonathan
Jason Robinson January 8th, 2009 12:00 PM
I just have any old LCD knockoff for secondary and then my laptop's LCD as primary, but then I have the firewire out going into my GL2 with s-video out from the camera into a 19" JVC SMPTE-C broadcast monitor. the boat anchor (aka JVC monitor) is what I use when I finally get down to the CC phases of an edit. Till then, I just roll along with the LCDs and think of everything as only "close" concerning colors.
Jeff Harper January 8th, 2009 12:06 PM
Ya know David, some folks use a television as a preview monitor with Vegas.
David Delaney January 8th, 2009 07:59 PM
thanks for the responses.
What I am going to do is keep the CRT monitor and buy a cheaper large monitor (like 28 inches). I can always use the CRT as a secondary monitor to check colors. Or in the future by a TV (maybe a small one) and use that.
