Can Vegas read timcode metadata on audio tracks?
Can Vegas 8 read timecode metadata imbedded in audio files? We Recently shot a feature on a Sony EX1 where we used a smart slate to send timecode info to the audio track (recorded on separate recorder).
If so -- What is the procedure in order to read timecode meta data (on audio tracks) in Vegas? The main edit is happening within Final Cut Pro -- however, I am putting together a trailer in Vegas. Right now I am syncing audio tracks to the slate clapper (visually), which is fine -- however, I wouldn't mind being a bit more precise... *Or* am I not understanding the timecode function within Vegas properly? Thanks -- |
James, I have been trying to find the same answer for a while, as I use an Edirol to record in .BWF. The only answer I received was that by looking at the properties of the audio file you will see the time code in the first frame. That's not very useful for me, and you probably will find the same for you as well. Hopefully someone will come across your post and give us an answer.
Chuck |
I'll state up front that I don't deal with BWF files. I've only read about them on various audio forums.
Both Vegas 7 & 8 are supposed to be able to read (but not write) BWF files. There's a lot more listed but here's a bit from the online help: You can also add Broadcast Wave Format files to your project by dragging them from the Explorer window to the timeline. However, if you drag a BWF file to the timeline, events are created where you drop the file. Using the Import Broadcast Wave dialog ensures that events are arranged according to the timestamps in the file. I searched the Sony Vegas forum (keyword BWF) and found a few threads that indicate this is feasible. James, please let the group know what you find out, good or not so good. Thanks. |
Mike thanks SO much for taking the time to look this up for us. I personally have never had an issue importing or working with the files. Mainly my issue is how to see the timecode of the file. Obviously you can’t view timecode on an audio track the way you would on a video track, so that’s where I’m stuck.
Chuck, step 6 of the online help says:
Choose a setting from the Positioning drop-down list to indicate where imported audio will be added to the timeline. Setting: Use ruler time Description: Adds each imported file to the Vegas timeline at the exact position indicated by its timestamp. For example, if you import a BWF file with a timestamp of 00:00:30;00, the media would be added to the timeline at the thirty-second mark on the ruler. This says to me that you'll be able to read the correct timecode on the ruler display. Or am I mistaken? |
Chuck, Mike - yes, that's a good summary of a typical BWF import workflow where you used time-of-day or other common free-run timecode on all cameras & audio recorders. Then, you would read the starting timecode of your matching video clip(s), and set the cursor to that TC in the timeline, snap the video to it. Then listen for echo between the camcorder audio and the audio recorder audio and slip (numpad 4 and 6) the audio audio to remove echo. This can be done at finer precision by turning off quantize to frames (but never slip/cut video without quantize "on"!! and remember to switch it back on when sync is done).
James - As to TC on an audio track, I think you're going to need an external LTC reader hooked up to an audio output to read the code. Unlike AVID and FCP, there are no native or third-party tools to read TC on an audio track for Vegas that I've ever heard of. I seem to remember Edward Troxel writing at some point that the scripting function doesn't offer a method to connect to TC on an audio track either, so it would be up to Sony to provide a solution on this. |
To Mike: That's a great approach that I have never though of, I see what you're getting at. So instead of seeing the timecode, it'll just get put where it belongs on the ruler. Only problem I am thinking about is that since I have to use time of day, and I shoot all day long, I may end up with a ten or twelve hour long timeline!
I guess if I was shooting something at say 10:00 A.M. I would set the timecode to start at say 09:30;00 and then import the audio files first before anything else? I can't wait to try that thanks again. To Seth: I have Blackmagic Decklink SP card, do you think I can set up an LTC decoder to one of it's outputs? Chuck |
Haven't used the BM cards - if you have a hardware TC input on it, and a sw utility to display TC... then it's certainly worth trying a soundcard output to the TC in. Then map the Vegas TC audio track to that soundcard output.
Here is a more detailed BWF sync workflow for Vegas along the lines that Mike suggested. |
Mike and Seth, thanks so much. With your help, I have finally figured out in this major hurdle in my workflow.
You guys are the best, Chuck |
