-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   How can I stop this?! (https://www.dvinfo.net/forum/what-happens-vegas/118578-how-can-i-stop.html)
Tony Spring April 4th, 2008 10:16 AM
1 Attachment(s)
Hi all
Hope somebody can help me to solve this problem. please see the jpeg attachment.
The project is a simple "3D Shuffle" transition with the clouds background on the lower video track, the upper track is two jpegs but I've used pan/crop to make them smaller than full screen and it's causing this masking problem.
Any advice much appreciated..
David Hadden April 4th, 2008 01:07 PM
it's because Vegas sees and moves a full frame of video over a full frame of video so one covers the other, and even though the one frame is "transparent" it's actually covering the other one.
Unless you're comfortable with 3D Track motion, I don't think you're going to find a way around it, but I don't think that it's necessarily an error so much as it's just the way it is when you're moving a full frame over a full frame.
Dave
Tony Spring April 4th, 2008 01:55 PM
Dave
Thanks Dave
That's what I suspected, I could do it with track motion but it would be too time consuming. I'll just have to use the transitions that work...
