-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   No WMV rendering... (https://www.dvinfo.net/forum/what-happens-vegas/117818-no-wmv-rendering.html)
Paul Kenyon March 26th, 2008 04:29 AM
No WMV rendering...
HI I am fairly new to Vegas but it seems pretty straightforward in the main. I am workign on an Dell XPS 720 H2C - quite a beefy machine and everything has been fine up to now.
Today I went to render a project as a WMV and I keep getting an error message saying that there are no templates for the selected projectthe he media may not support it.
I am sure this is about codec but I have everythign I can find installed and can't seem to find a similar issue on your forums.
Can anyone help?
When I go into the custom template window and select video and then format the drop down list is completely empty!
Please help!
Paul
Paul Kellett March 26th, 2008 04:39 AM
Hi Paul.
You've got footage on the timeline yes ?
Ok. So you doing, File>Render as>Save as type>Windows Media Video V9(WMV)
Paul.
Paul Kenyon March 26th, 2008 06:35 AM
Hi Paul,
Yes there is a project all set out in the timeline. On one of them I used AVCHD (.m2ts files I believe) from my Sony SR1 and on another it was simply a string of jpegs.
Yes as you described I am going to save as wmv but thats when the error message comes back.
Regards
Edward Troxel March 26th, 2008 07:23 AM
If the presets are not there, there is something wrong with your system. They are there in a standard Vegas installation. I would try installing Vegas again.
Paul Kenyon March 28th, 2008 06:59 AM
OK did a complete reinstall and still not presets. Anything else you would suggest? I had version 8d installed previous but just install 8 this time to see if that made a difference...it didn't.
Ian Briscoe March 28th, 2008 10:10 AM
Paul
You had version 8d installed???? You mean 7d?
Ian
Paul Kenyon March 28th, 2008 01:13 PM
hmmm... I seem to recall installing an update labelled d. Is the latest version 8.0c? If so would 7.0d installed over the top and screwed my build? I will install the latest update and see if I can get any joy.
Paul Kenyon March 28th, 2008 01:16 PM
No just checked at the website it is definately version 8.0d.
Mike Kujbida March 28th, 2008 01:23 PM
If it makes a difference, Paul is running Vegas Movie Studio Platinum, not Vegas Pro 8. The version number twigged me to it.
Paul Kenyon March 28th, 2008 01:25 PM
Ah, sorry - perhaps I should of mentioned that. Also I am in Vista if thats makes any difference. :-)
Ian Briscoe March 28th, 2008 02:49 PM
Ah - apologies for being presumptious.
But just think how good Vegas Pro will be by the time it gets to 8d......
Ian
Paul Kenyon March 29th, 2008 12:54 PM
Another error message coming back says that I do not have the neccesary window media video codecs? Where can I obtain these?
Jeremiah Rickert March 30th, 2008 03:40 AM
That's pretty strange that you don't have windows media codecs. They come with Windows, even Vista.
You can search for the K-Lite codec pack and install that. It has a pretty good pile of codecs.
Also, maybe you don't have windows media player installed? Under add/remove go to windows components if it's not there.
It's a real head-scratcher that WMV support isn't built-in. (unless it's a quirk with the UK version of Vista?)
Paul Kenyon March 30th, 2008 06:21 AM
Then this will do your noodle. Everythign seemed to work fine for a while. I have Window Media Player installed and thats still works fine. I have installed the codecs you suggested and that makes no difference. Vegas still tells me that the templates are missing or not compatible and thats after a complete reinstall!
Its beginning to do my fruit because I like to render videos for streaming to my xbox and wmv works best for that.
Any other ideas anyone? I am getting desperate and considering an OS reinstall...
Seth Bloombaum March 30th, 2008 01:29 PM
Originally Posted by Paul Kenyon (Post 850967)
...Any other ideas anyone? I am getting desperate and considering an OS reinstall...
I really have no idea what's happening here.
One possible workaround - install the freeware Windows Media Encoder 9 from Microsoft. If you can't encode from this, then yes, an OS reinstall may be needed (ouch!).
OTOH, if encodes from WME are working, you might then try vegas again.
