pan crop?
anyone know why I am having issues with this. it seems like the pan crop function is really limited, if I want to make 4 boxes, each holding their own video, it seems to work fine, a little tedius, but it works, the trick is when you want just THREE boxes, lets say two on the left side stacked vertically, and one on the right side, in the middle of the screen, the pan crop function makes it almost impossible to do this, how come you cant just make the individual boxes whatever size you want, and then place them wherever you want on the screen? does this make sense? anyone done this before?
there is a secret. You need to unlock the aspect ratio to be able to adjust the size to anything you want. there are 2 boxes on the side by the properties in the P/C window. One is for aspect ratio and the other is for keeping the center. Unlock the aspect raio and you're set to go.
You might also look at track motion for placement /sizing. Don |
yeah, I have used that aspect of the pan/crop function, it just didnt seem to be as free form as I would have liked. I will keep looking at it though.
thanks |
So use Pan/crop at Event level to Pan/Crop and Event's size and appearance within the FULL frame. Track Motion, can also be for single Events, IF that Event is on its OWN track, at Track Level. Once you have experimented with Track Motion, and you want to do the same in the future, you will not, use P/C for this result. YES, use P/C for the purposes for which it was intended (panning, cropping zooming-in and zooming-out)- yes. But for full frame, manipulation of Media in a 2-d or 3-d space, getting "boxes" of video stacking or flying through the air - then Track Motion. You will find the Track Motion Controls within the Track Header. Once you've experienced TM, try out its 3-D options!!! HTH Grazie |
| All times are GMT -6. The time now is 08:48 AM. |
