I can't find a way to "recall" audio tracks...
Hi,
I'm working on a project that has about ten video tracks and I didn't know that also the audio was important so i deleted the audio tracks from the project but know the chief told me to use also the audio... Do you know if there is a simple way to recall the audio of the tracks directly to the timeline? I think it would be an useful option! : ) Thank you! |
Make new audio tracks under the video tracks.
Double-click a video event to highlight it. Right-click it and select "open in trimmer". Right-click in the Trimmer window and select "audio only". Drag the audio clip to the timeline under the video clip. Repeat as necessary. |
Thank you very much!
The easier way is via a script. That's why I put the Restore Missing A/V tool in Excalibur.
Hi guys,
One of the reason why I ungraded to V8 was because of this statement by Sony about V8 under tech. spec./ Editing and Workflow features: A/V synchronization detect and repair http://www.sonycreativesoftware.com/...457&PageID=107 Do you mean to tell me this is not the case? I did search V8 for this feature and could not find it. Is there an additional plug-in that I have to purchase or install for this feature. If so this statement is very misleading. Thank you. |
The sync repair is that the track turns pink when out of sync
To restore synchronization, right-click the audio or video event you want to synchronize, choose Synchronize from the shortcut menu, and then choose a command from the submenu: |
Thanks Jim. The feature for A/V sync is available. It doesn't have a feature for missing audio. Gotcha.
| All times are GMT -6. The time now is 07:54 AM. |
