Multi-cam editing question
First question,
Can I use multi-cam editing with the demo of VV 8? Second, With multi-cam editing, if the time code isn't the same (ie; the cameras are not all started at the same time), can you still edit them with multi-camera mode? Do I have to line them up manually? Thanks |
yes you can as the demo mode is a fully functional program.
again yes, you can manually sync the tracks and multicam away. Don |
