-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Quicktime files??? (https://www.dvinfo.net/forum/what-happens-vegas/101368-quicktime-files.html)
Robert Brandon August 15th, 2007 04:10 AM
Quicktime files???
I have a short 10 second clip Im trying to drag into the timeline, and every time it says "an exception has occurred", then shuts down vegas. The wierd thing is, I just used the same clip on the timeline 1 hour ago! What could be wrong now?
Gregg Havens August 15th, 2007 06:23 PM
doesn't work now, worked awhile ago
Robert, A couple of things to try. If you are using a PC. Reboot the computer to clean up the memory or Ctr-Alt-Del to get to task manager and then processes, Right click on Vegas and set the priority to a higher level. That might allow Vegas to hog the CPU time and make the transfer work..
I've done one or both when I have Vegas start to glich. Works sometimes
Sony Vaio 3.2GHz, 1G ram P4 processor.
Douglas Spotted Eagle August 16th, 2007 01:20 AM
which version of Vegas, and which version of QT?
