Higher shutter speed for green screen?
Would a higher shutter speed give better edges to pull a key ?
I you're experiencing motion blur, then sure, a higher shutter speed will help clean it up.
Other things that help clean the edge by reducing green spill on the subject: More backlight/rim light. Then some more! Increased distance between the subject and the screen Magenta (minus green) gels on the back/rim lights. Reduced lighting level on the screen. |
Thanks for the tips Seth.
| All times are GMT -6. The time now is 02:14 AM. |
