How do I make an opening & ending shot open & close like an eye?
I'm curious about this. I was watching a couple of music videos. (Don't remember which ones, but I think you guys know what I'm asking here.
Let's say when the video starts it's a black screen, but the shot opens up as if a person is waking up in the morning opening his/her eyes slowly. (I don't mean the picture getting blurry.) Can anyone tell me how to do this in Vegas 7? Is it a transition, or are keyframes involved? |
If you mean the POV is from the "eyes" then I'd use a mask cut to shape, and then roll from there.
I didn't mean the pov as eyes, but I will keep that tip in mind too. What I was trying to say is that I want the opening shot to to be black then it slowly opens up until it's in widescreen. I'm having trouble trying to explain it. |
Then simply fade it in using a fade. Quarter circle upper left hand corner of the video clip, fade it in.
Just found a video showing excatly what I mean: http://www.youtube.com/watch?v=DmTpAnLzkGQ How do I do this? |
That would be a barn door transition, using the "out" no border preset.
Hi michael, i think i know what you mean. Basically you want the video to open up vertically from a black screen (like opening eyes). you have to go into the 'event pan/crop' for the video track you want to do this on and then pull the top middle ancho point downwards and the picture gradually becomes cropped from top and bottom until it completly dissapears. Make sure you have done this at the start of the clip (first keyframe). Now that you have what appears to be a blank image, move the cursor on the 'event pan/crop' timeline to the place you would like the image to restore to the aspect ratio you desire, and then right click on the image (the image in event pan/crop not the main viewer) and select 'restore'. A new keyframe should be added when you do this so you now have an image which starts a blank screen and opens vertically to the normal size of the video (remember once you hit restore in the earlier step you can re-ajust the image to what ever widescreen setting you wish). Hope this helps
didnt see douglas' last reply in time, it seems i've been doing things the long way for farrrrrr to long. BUt nether the less atleast you can do the effect now :)
Thanks you guys. So it can be done as a transition and event crop with keyframes. I appreciate both of you guys taking time out to help with this issue. Even though I've made some videos with Vegas, I don't know everything yet. I still have a while to go. Once again, thanks go out to both of you.
| All times are GMT -6. The time now is 11:31 AM. |
