Workflow
I've been working in my Final Cut Pro for about 8months now.
First I started off using Motion to do my titles and such, but without the rest settings I'd get a bit of pixelation... recently I figured a way around that. As of recent I've just typed my text in photoshop and save as a PNG. I start to import and ad various elements to my bin, then the question came am I doing things the right way? I often render while I cut and move along my timeline so as to see what things look like before I finish? Is that also wrong? |
You might catch more fish if you ask in the FCP pond.
Dante,
Photoshop is good for titles but makes sure that your image size is 720 x 534 by 72 pixels. You need to use 534 due the the fact photoshop uses square pixels and finalcut/video rectrangular so 480 causes scaleing issues. Also, do not use pure white text agianst a black background. Make it off white a little. And a soft drop shadow will also help if a non black background. The above for NTSC SD Have you tried using the Boris plugin that comes with final cut. It's decent. Mike. |
| All times are GMT -6. The time now is 06:40 AM. |
