-   Wedding / Event Videography Techniques (https://www.dvinfo.net/forum/wedding-event-videography-techniques/)
-   -   mp3 to aiff? (https://www.dvinfo.net/forum/wedding-event-videography-techniques/70541-mp3-aiff.html)
Michelle Lewis June 29th, 2006 03:52 PM
mp3 to aiff?
Does anyone know how to convert mp3 to aiff music file? I'm using FCP5. I attempted to convert it a few ways, but wasn't successful. Please help.
Meryem Ersoz June 29th, 2006 04:05 PM
use itunes. drop your aiff into itunes. go to preferences. click on advanced. click on importing. make sure "import using" is set to mp3 encoder. go to your advanced main in the main menu (not in preferences...), pull down and your "convert" menu will read "convert to mp3" so go ahead and convert it, the import/export to wherever you plan to use it....
Michelle Lewis June 29th, 2006 04:17 PM
Thanks but I want to convert FROM mp3 to aiff
Meryem Ersoz June 29th, 2006 04:30 PM
do the exact same thing. except instead of setting "import using" to mp3 encoder, set it to the aiff encoder, and it will switch the main advanced menu to "convert selection to aiff." sorry i misunderstood....
Michelle Lewis June 29th, 2006 04:57 PM
Got a message - can't be converted because protected files cannot be connected to other formats.
Meryem Ersoz June 29th, 2006 05:08 PM
http://www.dvinfo.net/conf/showthrea...iff+conversion
here's a link that will give you several workarounds for dealing with this...
Scott Routt June 29th, 2006 05:29 PM
Oooh I know this one! With itunes you need to first burn the encoded/protected mp3 files in the play list to a CD. That is what will turn those buggers into AIFs. You then Dump the AIFs from your CD onto your hard drive for use in FCP.
The catch is you can only burn a play list so many times, so make try to group your mp3 files in playlists. It beats making a CD for each single file.
Michelle Lewis June 29th, 2006 07:06 PM
Thank you guys so much. After all that, it was so simple.
Meryem Ersoz June 30th, 2006 08:08 AM
simple, yet such a pain in the #$%% to figure out...it would be much easier if Apple, knowing we need this functionality in FCP, would make this a feature...instead of forcing these lame and time-consuming workarounds...
*rant mode off*
Peter Jefferson June 30th, 2006 08:19 AM
glad i dont use a Mac...
if its this much hassle to manage an mp3 file, imagine trying to manage 160gb of MP3's... my head spins just thinkin about it
Meryem Ersoz June 30th, 2006 08:32 AM
the point is, it isn't a hassle when you know how to do it...it's easy...the point is, the information about how to go about it, which should be made obvious, isn't....
but i guess that's kinda the point of dvinfo, to provide the needed workarounds and super-secret stealth workflows, for all of this touchy equipment we use....
Michelle Lewis June 30th, 2006 08:54 AM
*rant mode off*
Yeah, I get what you're saying.
This is the first time I encountered this problem. I didn't want to go out and buy an entire album of the requested song. FCP is great otherwise.
Michelle Lewis June 30th, 2006 08:56 AM
It's really not about MAC, it's about FCP.
I love my MAC, Peter! I'd never ever go back to a PC.
Michelle Lewis June 30th, 2006 09:01 AM
It seemed all the instructions pointed to purchasing Quicktime Pro to convert the files. Slick on Apple's part! I know I should have gotten Q-pro a while ago, but I refuse to purchase to convert an mp3 file.
Glen Elliott June 30th, 2006 12:45 PM
It's not about the Mac OR FCP, but audio DRM. Try dropping your iTunes music into Vegas, PPro, Avid, or Canopus. It won't work there either.
