-   Wedding / Event Videography Techniques (https://www.dvinfo.net/forum/wedding-event-videography-techniques/)
-   -   LCD vs Viewfinder (https://www.dvinfo.net/forum/wedding-event-videography-techniques/60950-lcd-vs-viewfinder.html)
Craig Terott February 17th, 2006 03:18 PM
LCD vs Viewfinder
Cameras: PD-170 & VX2000
During a fast-paced wedding day I'm almost scared to use the view finder. Why? 'Cause every time I look up after looking through the viewfinder I realize I've been missing something just off screen that I wouldn't have missed had I been using the LCD.
It's like... if I use the viewfinder I'm restricting my field of view unneccesarily and miss things.
If I use the LCD I can frame the shot no problem and simultaneously pay attention to what's occuring around me.
Am I the only one on the planet that avoids using the viewfinder? I've heard the viewfinder (B&W) is better for focusing? But this makes no sense to me because the image in the LCD is larger and I can see more detail. The only time I use mine is outdoors, if it's blindingly sunny, and I can't see the LCD too well. Anyone use the viewfinder all the time? Why? Advantageous for a particular shot?
Joe Allen Rosenberger February 17th, 2006 03:58 PM
hey craig.....i "rarely" use the lcd screen on my pd150......i almost exclusively use the viewfinder.....
tip for using the viewfinder: shoot with both eyes open or atleast open your normally closed eye frequently.....it really takes some practice and getting used to but it works very well for me. the only time i use the lcd screen is when i white ballance and set exposures...jusrt for quick reference. doing this helps for focusing in my opinion plus i like the feel of how i handhold the camera.....if you're using the lcd while handholding....chances are....youre holding the cam away from your body which can result in unwated shake.
try it sometime....like i said, its takes practice to keep your other eye open or frequently opening the other eye so you can see what else is going o around you.....
Eric Hansen February 17th, 2006 04:11 PM
Hey Craig,
The only time I use the viewfinder is when I'm adjusting the manual settings for the lighting situation that we're in. I also use a glidecam to eliminate the extra shaking, so I really can't use the viewfinder.
The viewfinder allows you to see more detail of what is being recorded as the picture in the viewfinder gets interupted by the light so you don't see the exact colors and lighting that you are recording at. Then you can record from the LCD and not miss what's going on around you, but once the light situation changes again, check the viewfinder to make sure your adjustments are correct.
But if you're just walking around, I bet it would eliminate a lot of the extra shake like Joe mentioned.
Eric Hansen
www.ehansenproductions.com
Edward Slonaker February 18th, 2006 08:13 AM
Have you tried using an LCD hood for your camera? I use my LCD almost constantly but the glare from the sun down here can be brutal.
http://www.petrolbags.com/new_petrol...cessories.html
These folks make great fold down hoods and they work wonders. B&H carries all their stuff and the prices aren't bad.
Evan Shaw February 19th, 2006 08:15 PM
I shoot alot of sports and I got started using a pd-170. I almost exclusively use the LCD because I'm able to hold it much steadier than with the viewfinder. I also like being able to see and not tripping over things... when I'm using a full size such as a DV5000 I usually flip the viewfinder magnification up and out of the way so that I don't have to have my eye buried in the finder. It just feels much more natural... but I'd say go with whatever is the most comfortable for you...
Travis Cossel February 19th, 2006 09:01 PM
I go with whatever 'feels' best for the situation I'm in. During a ceremony, for example, I might switch between the two multiple times. During the reception I use the LCD almost exclusively.
I would say, overall, I use the LCD the most.
