what is this slider?
So I've just seen a short clip where the guy is using a very short slider but the slider itself travels as well as the sled so it looks like it gets as much travel as my Glidetrack but is physically much smaller. In my quest to lighten the load it looks interesting
About 32 seconds in |
Re: what is this slider?
Think I found it
http://www.bhphotovideo.com/c/product/1038722-REG/edelkrone_80842_slider_plus_pro_medium.html Anyone using this and care to comment? - a little pricey and looks like it won't just sit on the floor - I like that my Glidetrack can be just plonked down and slides for a nice low angle |
$600 dollars and you can't even place it on the floor. Aprils fools was last month Edelkrone
It's unique in it's function as 1. you get a much longer travel then any other comparable slider that has the same length, 2. you can attach a actionmodule that can have preset speeds for controlled repeatable slides + 3. you can attach a targetmodule that will lock onto a subject and follow it when the slider is sliding. I have all 3, used the action module and slider on a recent shoot, (not a wedding) and what I liked most about it was that I could repeat my slides at exactly the same speed and also control how smooth it starts and stops which makes doing second or 3rd takes a piece of cake as I can focus on my camera and not the motion. You might argue it's expensive but I have had some cheaper ones before and you feel the difference for sure. The good stuff is never cheap. |
I like it; can't afford one this year, but definitely on my radar as something to add to my gear.
Paid $2k for the extra long one a few years back, it's held up pretty well, very smooth. The shorter one is better - the XL one (and anything longer than what you see in the video) can't be held up in one point... it starts to tip once you get very far to either side.
Tbh i have a £300 glidetrack that is pretty crap - it sticks constantly, especially when going from cold to warm and vice-versa - really hard to get a smooth glide. My budget has already been blown this year but Neewer do a version of the edelkrone for about £100 that i might try - it can't be as bad as my Glidetrack
I get that its different and has limitations, but the idea of a slider short enough that you could probably leave it on your tripod for most of the morning appeals to me.
It's a very nice bit of kit. The only flaw is that the adjustable feet won't go high enough to clear the floor if you have a manfrotto plate on the bottom. Only discovered this after I bought it. Needs to be solved but the best slider I've had in my time.
Well that rules it out for me as I quite often have the slider on the floor as well as on my tripod - shame
Yeah, it's on carpet where things go wrong. Often dealing with carpet during morning preparations.
Plus it's super easy to loose the feet as they don't stop themselves from being able to be unscrewed from the body.
| All times are GMT -6. The time now is 09:07 PM. |
