Archiving RAW footage to 25gb & 50gb BDR
As the title really.
Opinions ? With the cost of hard drives coming down but still having reliability issues (most recently I purchased a brand new western digital drive directly from WD UK it failed on me within a few days of use - dreaded clicking sound issue but I did have ANOTHER backup). I was thinking a more permanent solution would be simply backing up the RAW wedding files to several BDRs that are WRITE ONCE only. The cost of discs are DIRT cheap having a quick look on Amazon. Quality Printable Verbatim 25GB 50 pack spindles can be purchased for £20 - £25. An average wedding lets say has 100gb of RAW, that's 4 discs at approx 50p a disc. Yes they are write once only but the main thing here is you will always have a secure copy of the raw files with no risk of a mechanical drive ever failing on you. |
Re: Archiving RAW footage to 25gb & 50gb BDR
Even if the BD-R discs were reliable long term the time & effort in burning the discs would rule it out for me. There is very little difference in cost as a 4TB HDD is about £100 i.e. £1 for 40GB vs. £1 for 50 GB BD-R With either medium you wouldn't want just one copy anyway.
BDXL discs are 100GB and can be had for $65/5 pack on eBay (make sure you have a burner which supports the format). I stick with good brands (Verbatim) and don't have an issue. With hard discs, I can definitely see needing, at minimum, two drives, but with quality BD discs, I would just burn one copy. In fact, doing that right now for some older projects I wish to archive but don't need to access.
To compare prices in dollars I see that a 4TB external HDD is about $120 on Amazon.com whereas 4TB of BDXL discs even at those cheap eBay prices would cost $420, |
Ideally, you use a RAID enclosure (I have several) that automatically duplicate the drive contents for you and make it easier to spin up both drives on occasion. I'm not saying Blu-ray is the best way, but for larger projects I probably won't even touch again, it makes sense. It frees up space on my RAIDs for current work, I'm not just trashing things, and I don't have to worry about it as much. LTO tape is probably one of the most ideal solutions, but even that is not 100% foolproof, and it's a nearly $4000 upfront cost to me to go that route. I just picked up another set of BDXL discs (under $200) and dual 6TB drives and a Thunderbolt enabled Guardian Maximus enclosure (under $1000) and I'm set for now. |
It's the quickest way for me to back up and keep off site as cheaply as possible.
£2-3 tops for me to back up the RAW footage of a Wedding i've just filmed. In conjunction to using external hard drives, I think it's the best way for me have some peace of mind that I have backups on multiple devices. |
Home burn DVD and BluRay are using dye to represent 0's and 1's. They are affected by sunlight. I would suggest archiving raw footage to bare HDD. they are very cheap. Also sign up a cloud backup service. I use CrashPlan which is US$5 a month unlimited storage. Once I stored files there, they won't delete them until I explicitly remove them.
There's a distinction between backing up and archiving. Archiving is long term preservation of important files and must take into account accessibility and readability of the media. That's dependent on a number of factors but the time horizon for access to the data plays a role. Hard drives are not a long term (for me 25 year or more) solution. Currently the two best solutions I know of are M-Disc and LTO. M-Disc is an archival disc with a projected 100 year or longer life that's available in a 25 GB BD version writable by normal BD writers. Your greatest risk with those is probably availability of a reader on the tail of your time horizon. M-Disc is a pretty good solution for small archiving projects like a copy of someone's wedding footage, family photos, etc.
All great points.
But I think for my needs BDR's suit me fine. I simply require a back up until delivery of the final product to my client. So lets say 6 months max ?? external hard drives are fine at the moment. But rather than uploading to cloud, using BDRs to quickly burn at my convenience, storing them away in a dark cupboard away from the harsh UV rays of sunlight is safe enough in my opinion. I still have CDRs that work which I burnt nearly 15 years ago. |
| All times are GMT -6. The time now is 06:00 AM. |
