-   Wedding / Event Videography Techniques (https://www.dvinfo.net/forum/wedding-event-videography-techniques/)
-   -   A question about 16bpc editing (https://www.dvinfo.net/forum/wedding-event-videography-techniques/526737-question-about-16bpc-editing.html)
Jeremy Lee February 2nd, 2015 11:12 AM
I am wondering if someone could look at my workflow and let me know if it looks right. I did post this in the Adobe forum but have yet to get a response. Thanks..
I edit the master sequence in Premiere CS6
I then group the entire sequence and REPLACE WITH AFTER EFFECTS COMP
In After Effects CS6 I work in 16bit and do all my coloring and effects.
Going back into Premiere I now have a Premiere Sequence that is ready to be mastered out.
Does this look right to everyone?
JDL
Adrian Tan February 2nd, 2015 12:45 PM
Re: A question about 16bpc editing
Looks good to me, but I don't know that much about AE. I'm pretty sure that if you work in 16 bit in AE, you'll preserve some of that detail even if you output to 8 bit.
In terms of rendering times, I don't know. It might be better to not convert the entire thing to AE comp, but just the parts you want, and otherwise do as much within Premiere as possible. Worth a test...
Also, to be picky, I don't think you need to group everything. Just marquee select everything.
