Recommendations on a camera mount that will stick to a stage or smooth surface?
Have an event coming up and just found out that I cannot put a tripod at the foot of the stage. My only option is to mount my camera directly on the stage on a wood mantle piece that is along the staircase to access the stage (it's a highly varnished piece, so it's smooth and non-porous). Oh, and the mount has to hold the weight of a Sony CX500V with a Bescor remote tilt/pan head attached. :)
I've looked at the Fat Gecko systems and some suction cup systems intended for vehicle use, but I'm just not sure of the stability with the camera panning. Thoughts? |
Re: Recommendations on a camera mount that will stick to a stage or smooth surface?
How about a hi-hat with some sandbags? Add some grip tape to the stage if the hi hat still wants to slide all over.
I've had a lot of luck using the 4 suction cup sticky pods - BUT not sticking them down, simply using the stiff rubber sitting on the surface - it also seems to work as a shock absorber. Attach the pan/tilt head to it and it's surprisingly solid.
Suction cups require a very smooth surface in order to grip - including the Fat Gecko double suction cup ones which I have, so if you go that route do make sure you test them on the actual surface first. I have been able to use them on painted doors and they easily hold a panny TM900 which is similar to your cam in form factor and weight.
A safer bet would be to use a large clamp such as the Manfrotto Super Clamp - so long as the edge of the stage or the mantel has a sufficiently narrow and non-sloping edge that it can grip to: Manfrotto 035C Super Clamp - Brackets Clamps Then add a manfrotto heavy duty flex arm to get some height: Manfrotto 237HD Heavy Duty Flex Arm or a rigid Manfrotto extension arm: Manfrotto 042 Extension Arm Both of these plug directly into the superclamp and so cannot unscrew themselves or come loose - which can happen with friction arms. You need to top either with a suitable ball head to enable you to level the horizon etc accurately. Pete |
Thanks for all the suggestions guys.
After doing a lot of research, I think I'm going with this: http://www.bhphotovideo.com/c/product/570555-REG/Delvcam_TT1048_TT1048_Video_Big_Foot.html Between sandbags and gaffers tape, I think I can get a lot of different uses out of it without a big investment. |
| All times are GMT -6. The time now is 10:10 PM. |
