-   Wedding / Event Videography Techniques (https://www.dvinfo.net/forum/wedding-event-videography-techniques/)
-   -   Delivering in Thumbdrive (https://www.dvinfo.net/forum/wedding-event-videography-techniques/515232-delivering-thumbdrive.html)
Sean Seah March 21st, 2013 11:11 PM
After experiencing several crappy blueray players we are thinking of delivering the entire wedding video on thumbdrives.
Only one issue is we cant figure out how to do a menu. I am aware Flash can do it but it seems quite over the hill now. We need a menu as well deliver a documentary edit in chapters on top of the highlights.
Nigel Barker March 22nd, 2013 01:17 AM
Re: Delivering in Thumbdrive
Sorry but it can't be done. There is no standard way of providing menus on a USB stick. The problem is that you don't know what it will be played on. If it was only going to be used on a compute then it would be easy to create a page in HTML to use as a menu. However what if they plug the USB stick into a TV or a Blu-ray player or a networked HD media player? You could create an ISO of a Blu-ray or DVD which some media players can play just as if it were a disk but then it won't play elsewhere.
Chris Harding March 22nd, 2013 03:00 AM
Hey Nigel
I remember asking the question a couple of years back as it would be nice to have. I have however found that if you split the wedding video into logical segments (mine are already compiled that way) so you have a clip for bridal prep, a clip for the arrival, a clip for the ceremony etc etc and then name the MP4 clips with a sensible name so instead of seeing MV0012.mp4 the client's TV/media player will list files like BridalPrep.mp4 and Ceremony.mp4 and that would allow them to at least see what they have selected to watch. Most TV's and Media Players do list the files on the drives so you can select what you want.
Chris
Roger Gunkel March 22nd, 2013 08:18 AM
Hi Nigel, as Chris said, splitting the wedding into segments is pretty much what I do as well. Just keep them to logical breaks, rather than halfway through the ceremony. Many players, tvs computers etc, will roll from one segment to the next automatically, so it's not really a problem. If you tell your client what to expect, they are unlikely to be bothered, as most seem to just hit the fast forward when they want to move on anyway.
Roger
Nigel Barker March 23rd, 2013 02:12 AM
Guys, I know all that.
Sean wrote " We need a menu" & I told him why he can't have one.
BTW You need to name the files something like this to get them to play in the correct order
001-BridalPrep
002-Ceremony
003-Speeches
004-FirstDance
Dave Partington March 23rd, 2013 04:46 AM
What codec and resolution are you encoding these files to?
Chris Harding March 23rd, 2013 04:58 AM
Hi Dave
I do mine in Sony Vegas as a standard MP4 file (called Sony AVC) which is 1280x720 and I use their hi quality internet template ...it looks pretty good on a big TV! It's at 25P and a bitrate of 8mbps
The reason I use 1280 is cos some of the smaller LCD TV's here are not genuine 1920x1080 resolution but something between 1280 and 1980 ... strange but true so I decided to stick to 1280 ..also some brides also may have their laptop res lower than full HD as well.
Thanks Nigel ..yes my files are named so they stay in sequence otherwise the first to come up is usually speeches which is not what you want!!
No complaints so far!!
Chris
Dave Partington March 23rd, 2013 05:19 AM
Chris - thanks, but MP4 is just a container, like .mov. What 'codec' are you encoding to ? Is 'AVC' an H264 file? None of my TVs or any one else I can find will play H264 files in an MP4 wrapper.
Chris Harding March 23rd, 2013 05:36 AM
Hi Dave
I have no idea at all!!! I would suggest a post in the Vegas forum maybe? I just know that it seems to play on anything I put it into!! That sorta tells me it's probably not H264??
I'm sure someone will know
Chris
Roger Gunkel March 23rd, 2013 10:45 AM
I just ran a 10sec clip from some MTS 3d video into Magix and rendered it out as a 2d H264 mp4 file at 1920 x 1080. I put it onto a usb stick and it played with no problem in my Samsung tv. It also played in my laptop in Windows Media Player.
Roger
Dave Partington March 23rd, 2013 10:52 AM
Thanks Roger. Perhaps I could ask a few more questions ? :)
What level of H264 are you rendering to (1 - 5.1) ?
What Profile (Baseline, Main, High) ?
What bit rate are you using ?
Roger Gunkel March 23rd, 2013 11:33 AM
Ok some of this is out of my league, I work on if it looks good it is good, but here goes
Preset = AVCHD
Profile = High
Level = Auto
Performance=9(balanced)
Frame type= Progressive
Slice Count= 1
Rate Control Mode= Variable bit rate
Rate Control Pass=Single Pass
Bit Rate= 6000kbs
In addition, I am using PAL at 25fps. And the codec is by Main Concept
This gives about 20 minutes per gigabyte although I think max file size for playback of mp4 may be limited to 4gb. Others can probably give more info on this as there seems to be conflicting info.
Roger
