-   Wedding / Event Videography Techniques (https://www.dvinfo.net/forum/wedding-event-videography-techniques/)
-   -   Glow to white transition (https://www.dvinfo.net/forum/wedding-event-videography-techniques/50235-glow-white-transition.html)
Christopher Farrugia August 30th, 2005 01:40 AM
Hello everyone,
I would like to know how to achieve that effect which Glenn Elliot uses a lot i.e. That transition that glows to white and then from white back to video.
I use Adobe Premiere.
Thank you a lot
Chris
David Chandler-Gick August 30th, 2005 06:56 AM
It's called a Dip to Color transition.
If you don't have such a transition already, you can emulate it by cross disolving to a white still (RGB 235,235,235) and cross disolving back to video.
Lloyd Coleman August 30th, 2005 08:45 AM
I would love to know a good workflow to do the same thing in Premiere Pro. I think it is more than just a dip to white. There is also some diffusion and a boost in the whites in addition the the whole frame getting lighter.
John DeLuca August 30th, 2005 08:51 AM
http://www.dvinfo.net/conf/showthread.php?t=40881
Nick Jushchyshyn August 30th, 2005 08:52 AM
In MediaStudio Pro the video filter that does this is called "Diffuse Glow", maybe there's a similar effect in Premiere?
Just keyframe animate to start with no glow at all and transition to an overcranked glow that fills the frame. Reverse this progression for the next clip and you've got a glowing/flash transition.
The effect has been around for a long long time.
Works well for action montages as well as "mood" pieces for weddings:
http://www.jushhome.com/nick/media/nbbfintro.mov
Have fun.
Mike Cook August 30th, 2005 09:50 AM
A quick and easy PPro solution is a combination of blur and levels. You can blow out to white with levels and add some blur while you do it then reverse.
Mike
