Iriver
Can someone tell me if a IRIVER Model 895 is a good one taping audio and how long will it tape voice ?
Thanks Mike Long |
I'm not trying to be lame here, but you'd do yourself a big favor by searching the forums for the word "iRiver". There's a ton of threads on the subject already with a lot of information. In a nutshell, a lot of people have had some good sucess with these devices, but they are not pro audio equipment, so it depends on what you're trying to get out of them.
i have the 2 x iriver 790 its 256mb for my wedding coverage and they record 2.5 hours each at 224 KBPS stereo 44.1KHz, for me they are small reliable and cost effective, they give out quite faithful audio and are more than good enough for recording vows, speeches etc......
of course yours is 512mb so double the record time.....! Mike |
it would, i use the higher setting purely because of the manipulation needed when equaling the differnet voices from the vows, theory being the higher the quality the more I can squeeze good audio out of it..?? for straight recording under better conditons and consitent levels, then i agree and I would too use a lower bitrate. |
Actually a setting of 128kbps mono is higher quality than 224kbps stereo.Thats because stereo being 2 channels each channel is using 112 kbps.So the 128 is slightly better than the 112.I normally use mono and because it adds so much time I use 160kbps.But you must use either a rewired mic like the GS for iRiver or an adapter such as the one I made.(normal adapter doesn't work)
Yes jack, i am using a modified lav mic done by darrren (GS) well, then i will try to jack it up to 162kbps then...i wonder how long will be the recording for a 256 MB...well i have to see it on myself. :)
Considering that the iRiver is recording in the lossy MP3 format, and then you are eventually going to compress it again during render (to whatever format), I'd always go with the highest res bit rate possible if I were you. It's kind of like if you ripped a music cd to mp3 format, then re-encoded that mp3 to ac3 -- that's two lossy compressions in a row. So, it can only help to go with the highest bit rate possible if you have the space on the flash.
