How happy are you with iRiver?
The last wedding I did I used my wireless mic, only since it was an outside wedding there was another wireless mic (that the dj brought) set up to speakers and there must have been some type of interference because the audio to my camera wasn't as clear as usual. I've noticed a lot of people talking about using the iRiver, is the quality really good?
Keep in mind there are drawbacks to the iRiver here's a run-down: Pros - inexpensive - have line-input for use with a variety of mics - small footprint (unobtrusive) - doesn't use a wirless signal so your less likely to have an officant worried about wearing one - resulting audio quality is superb (when coupled with a decent lav mic) Cons - no way to monitor the audio signal - have to sync it in post (and it doesn't hold sync for LONG periods of time) - limited recording formats/settings |
I have been wondering the same thing, except I have found that the newer iRivers don't have the mic input.
"It doesn't hold sync for long periods of time."
It does hold sync perfectly - it does a fantastic job. When I sync audio I use muffed ear phones, at a louder than normal volume and listen carefully for the slightest echo. I tweak until echo is gone. I can dump well over an hour of I-River audio in the timeline, sync the begining and go right to the end and hear not even hear a hint of echo. Not even a hint. I use either the 256kbs or the 320kbs settings and neither setting on even one wedding have ever lost any sync. Prior to the two 790's, I had used another brand of VR and yes - I had to re-snyc about every 10 minutes. To my delight, I've never had to re-sync since buying the I-Rivers. Glen, for anything else I yield the floor to you, but on this point you're wrong. There is no issue with sync and I-River. It could easily be one of your "Pros." |
Glen,
Is it possible you are importing the audio as a 44.1kHz file and placing in on the timeline with camera audio recorded at 48kHz? Wouldn't that account for the minor drift you are experiencing? |
Hi Jennifer,
Here are the thoughts of an old dog trying to learn new tricks. FWIW. :) http://www.dvinfo.net/conf/showthread.php?t=49556 |
I have had no problems as long as I first convert the sample type. I use Adobe Audition and simply import at 44100 Hz and then choose Convert Sample Type from the edit menu, selecting 48000 Hz. The audio retains the same pitch and duration as the original file and shows no noticeable drift in Premiere Pro, even when over an hour long.
how long are you using this method of importing and converting with audition? just like what glenn elliot have said...have anyone confirmed and tried this? |
Mark |
