Spinning platform for rings
I have seen some good close-up shots (usually with a DSLR and macro lens) of the wedding rings slowly revolving on some type of platform \ support.
I think this movements adds a nice change from the linear movement of a shot from a slide. My question is: what are these spinning things called and where can i get one? |
Re: Spinning platform for rings
No idea what they're called but as a low budget alternative I've used this:
IKEA | Serving pieces | Serving dishes & bowls | SNUDDA | Lazy Susan With some black velvet and a tiny rope to pull and to make it rotate you have an excellent rotating disc for smaller objects. regards, Erwin |
If you're talking about what I think your talking about, they are called "turntables" just like the "old fashioned" record players, which I still have one. Doesn't work, why keep it. Oh well, I digress.
Display turntables can be purchased as shops that either manufacture them or stores that have them and aren't using them. Sometimes you buy them from the store as a used display. You can also make one, I did that a few years ago. Friendly local home improvement store for the compostie board, IIRC the ball bearing rings came from a tool supply house, a little band saw, a little orbital sander, some nice material to cover, bake at 500 for 30 minutes...wait wrong reciepe, sorry. Anyway you get the point. Keyword, Turntable. |
Hi Dan,
Throw a cover (I just use a table napkin at the reception) on your tripod head and use the handle to turn it. Like this at :30: ~ LAURA AND JOHN | SAME-DAY EDIT ~ Or I suppose you could attach a tripod plate to a platform if you need a bigger space, but you only need a few square inches for rings. I priced out a lot or bulky, expensive options last year to do this but the last thing I need is to carry more stuff. This has worked perfectly and the only thing I needed was a macro tube set. Quote:
Joel,
never thought about using the tripod head. Great idea. |
Yep, Joel ... I'm going to steal that move! Great idea and thanks for sharing it.
Steve |
Could you explain what a macro tube set is? Are they the same as an extension tube? I shoot with a T2i using a 50mm 1.4l, but I doubt I could get that close...
Hi Michael,
Thanks for the info and ideas chaps!
Joel, I have just bought a set of the extension tubes (the no contacts ones) for my 60D. If I use my Canon EF 50mm 1.8 with them, are you saying the aperture will be locked at 1.8? Thanks |
50 1.4 items - Get great deals on Lenses, sony 50 1.4 items on eBay.com! Just make sure the lens surfaces are clean and they don't mention fungus, haze, oil on the aperture blades etc. When you find one order the appropriate adapter too - search for "Nikon EOS adapter", for example. To get it within a few days rather than weeks select "US only". Buying from the east may be cheaper but shipping can take weeks, especially now with the earthquake. (Hope all our readers and their families and friends from that area are ok.) |
Thanks very much for that info Joel, i dont use my 50mm 1.8 much at the moment so using it with the rings should be fine if i switch the focus to manual on the lens. I was planning to do most of the macro stuff at 1.8 so that's fine!
| All times are GMT -6. The time now is 11:36 PM. |
