If you are recording two channels independently in camera, you should be able to lower the volume on to a level good for applause and the other a little higher for speech. In post you just just duplicate the left channel on one audio track and duplicate the right for the other, then blend the audio tracks together.
Basically you need to attenuate one mic and not the other. Hopefully I'm not repeating what others have said, if so... you won't forget it :) |
I used a recoder wired to the output of the DJ's sound system. He was using a wireless handheld mic for the speech makers.
On my cam I had my shotgun sent to ch1 and 2. One channel was set considerably lower than the other. I can then use the recorder audio for the speech dialog and the cameras audio for background and applause. Since one channel is set lower than the other I should have my choice of which to use based on how loud things are. |
thank god I live in the land of the lecturn! |
Hi Paul
I was actually quite amazed..it seems that we are the only country in the world where the reception venues supply a lectern!!! It's our gain however..you have a pretty much standard mic position and the person doing the speeches stands relatively still!! Makes our job a lot easier!!! I have already heard of techniques like hiding mics in floral arrangements and moving them in front of each speaker at the bridal table but the lectern still beats them all and we get pretty good audio!! Chris |
