Delivering SD from HD
We have just switched to HD cameras (Panasonic HMC150s) and have some questions on shooting and exporting. For weddings that will be delivered on DVD what format do you shoot in?
How do you export from Premiere Pro CS4 to retain the best quality. Where the footage is HD can you zoom in and retain quality when outputting to SD? thanks |
Hi Janice
It all depends on whether you are going to edit in HD and then render down to SD or rather transcode to SD first. (Panny have a free transcoder..I left a link on the AVCHD forum) It's probably better not to shoot in interlaced mode as HD and SD fields are reversed so progressive footage will downsize better to 720x480 without interlacing lines in the source footage!! Unfortunately I use Sony Vegas and there are extensive threads on the Vegas forum about HD to SD but I prefer to transcode my AVCHD direct to SD first and then edit as the render times are a fraction of rendering HD to SD. It just suits my workflow. When I come back from a wedding shoot I actually create two folders for each camera card..one is AVCHD and the other is transcoded SD AVI so even before I start I have a choice which way to go!! Chris |
How do you like the quality when you convert to SD dvd chris?
the HMC150 delivers gorgeous SD product shot in 720p. I actually sat down and watched my work with a wedding planner and was amazed at how good it looked in SD. now keep in mind, i NEVER watch the discs I make. I send them out and done. From what clients have told me regarding the blu ray product, it looks like you are there with them. I still dont have a blu ray player
Hi Kiflom
I have done countless tests with AVCHD, HDV and SD all to a DVD in the usual MPEG2 format and on a 42" LCD TV you have to look pretty hard to see any differences!! Remember that you are comparing clips against each other !!!! Give the bride just one DVD and she wouldn't know the difference!! I'm 100% happy with my SD transcoded quality. In fact shooting at the lowest bitrate there is no resolution change either but you will get a few artifacts and even vertical line skews. Edit AVCHD to SD and render 10 minutes of video in 30 mins or more or edit SD rendered to SD in under 5 minutes???? I need the faster workflow I can't have both computers tied up for hours and hours rendering footage!! Chris |
I actually shoot all my video interlaced!! 1080i but that is my preference. If you are going to transcode to AVI directly then you can shoot progressive or interlaced. However if you are intent on going the AVCHD to SD route then it's essential to shoot is progressive mode so you don't have any interlacing line issues during downsizing.
If you do use the Panasonic transcoder don't shoot in 720P as it doesn't handle that mode for some reason!! It's free so you might as well try it anyway??? Chris |
HD to SD is always a hot topic. I find that in CS4, editing HD, then using the active link (or whatever it's called)direct to an Encore timeline gives good results. I tried these methods in a test, and rank them from best image quality to worst:
1. HDV 25p (or Cineform 25p) Premiere output to a1920x1080 25p cineform file. Then I use Procoder 3 to make a MPEG-2, then import this to Encore. Looks great, but is time-consuming. 2. HDV timetine active linked to Encore, let Encore encode. Looks great, and is easy and fast. Using just Adobe tools, this is clearly the best way. 3. Export HDV using AME High Export Quality MPEG-2, then imported to Encore. Not as good, long render, more artifacts, but doable. 4. Same as 3, but not HQ. Softer, artifacts, barely usable. I often pan-and-scan and zoom in to reframe or adjust tilt. I find it is invisible up to about 135% , but noticeable beyond this. |
I shoot hdv with my a1 and use AME to make mt2 files for encore and the result is great. i also use encore direct from premier and the results are the same. i am getting a new camera but don't what get yet. iam also getting a new pc with a lot of muscle to go with my new camera.
Hi Guys
Just bear in mind that Janice has an HMC150 so HDV footage doesn't really come into the mix. The camera shoots in AVCHD format so she would be more interested in using AVCHD in Adobe CS4 ..(I use Vegas 9 so I cannot help here, sorry!!) I think what's needed is a CS4 workflow using AVCHD footage A Quadcore is fine for AVCHD editing..I can even manage stuff on my DuoCore!!! Chris |
That is right Chris.
Thanks everyone on the information. Maybe I should start a new thread asking if anyone is editing AVCHD in Premiere CS4 and start there. |
Hi Perrone
I said I can manage stuff on my DuoCore ... I didn't say it's awesome!!!! Unfortunately the preview battles somewhat!! especially over transitions. Straight video previews pretty well but as soon as it hits a speed bump it struggles... The point here was that yes, I can physically take an AVCHD clip ..drop it on the timeline and render it out to an MPEG2 SD video. DuoCore 2.2GHz with WinXP and 3GB ram. The only stuff I have done in AVCHD is test clips really...all the weddings are transcoded to AVI first and, of course, the files run sweetly without any hiccups!! Sorry if my post made it look like I was running AVCHD perfectly on a DuoCore, however you CAN do it if you are patient!!! Chris |
