tips on using a smooth shooter
Okay I used my smooth shooter for the first time at a wedding a couple of weeks ago and I thought I had practiced enough but my shots aren't as smooth as I expected. anyone have some good tips to offer. I have another wedding in a couple of weeks and would really like to use it again but I want to make sure I am shooting smooth shots.
Hi Lalo,
Practice, practice, practice. If you notice the bobbing motion I did let the springs loosen so you have to pick the arm up yourself. It takes the bobbing away. Be very sure footed and slow in you movement. Move before the shot you have envisioned so that you are already moving when the time comes. Never walk sideways or foot over foot, always be moving forward of backward. Try practicing with an x on the wall and move toward and away while maintaining the x constantly in frame. If you have kids, film them outside, try to do as much as you can. Make sure the sled is balanced as well. If it is not the footage will be considerably unsteady. Hope this helps |
Thanks Jason, I will continue practicing. You said to loosen the spings, do I loosen until the arm is below being perpendicular to the ground? right now it has about 5 degree angle not much but some. Do you put your hand on the camera at all when filming or just when hitting record and pause? Where do you normally put your hands?
Lalo,
I found that when I had the arm properly set to where they recommended I was getting a bobbing effect with the camera. I let the spring tension right to zero so I had to pull it up to where I wanted it to be. This eliminated the bouncing effect and I had much more control of the rig. My right hand is on the sled handle and my left is lightly touching the sled below the gimble. I never put my hand on the camera unless I am adjusting the exposure/focus. When flying never touch the camera as it will throw off the inertia and balance. I was using the 4000 sled and a canon xh-a1. I also made the sled very heavy, I think I had 3 plates on the top. The heavier the sled the better it will fly with stability. Think about your shots before yo shoot as well and practice them before the shoot, this will help you understand what to expect. Anymore questions let me know. |
Make sure you practice practice like everyone else said. Fix the tension on the arm.
Also, what I found in the beginning was that I tried to take too much control of the gear but I found that once it's balanced u gotta let it go by taking minor control on it. As in let it flow and move yourself around it. |
