-   Wedding / Event Videography Techniques (https://www.dvinfo.net/forum/wedding-event-videography-techniques/)
-   -   Battery for Sony HVL-20DW2 20 (https://www.dvinfo.net/forum/wedding-event-videography-techniques/128031-battery-sony-hvl-20dw2-20-a.html)
Troy Davis August 14th, 2008 01:40 PM
Hello,
I have a sony 10/20 watt on cam light that I use at weddings and it's a battery hog. Are there any recommendations on a longer lasting battery for this light? By the way, I have the NP-F970 battery. I'm also looking for lights that are similar suggestions?
The light can be found here: Sony | HVL-20DW2 20-watt Video Light | HVL20DW2 | B&H Photo Video
Dave Blackhurst August 14th, 2008 04:08 PM
How long are you getting out of your 970? That's a pretty hefty battery and should last fairly well unless it's on it's last legs. IIRC that's the biggest one Sony makes, I usually go with the 7xx batteries myself for weight, but have a 9xx handy for backup. I would suppose you could make a belt pack using a dead battery for an adapter without too much trouble...
Rick Steele August 14th, 2008 05:23 PM
Here's an new NP-F975 that's rated a bit higher than the 970's. It's not a sony but I've been using this brand of batteries for a long time with great results.
Impact | NP-F975 Lithium-Ion Battery | NPF975 | B&H Photo Video
I haven't tried this one though. The "Impact" 970's work fine in my light and I wouldn't know why this wouldn't either.
Alex Dolgin August 16th, 2008 06:56 AM
Originally Posted by Troy Davis (Post 920506)
Hello,
This is about 47wh battery. Your light should last at least 4 hours on it in 10w setting, a little less than 2 hours in 20w setting. May be you need a new battery if you are not getting this run time...
Troy Davis August 28th, 2008 09:18 AM
Thanks everyone.
