-   Wedding / Event Videography Techniques (https://www.dvinfo.net/forum/wedding-event-videography-techniques/)
-   -   Focusing.. Auto or Manual (https://www.dvinfo.net/forum/wedding-event-videography-techniques/121712-focusing-auto-manual.html)
Denny Kyser March 5th, 2008 09:13 AM
Ok, asking this in this forum because this is where I will be doing most of my video work, in weddings.
Do you use Manual or Auto, or Both.
I have heard Manual is the way to go, but here are my concerns.
1) My eyes are not as good as they once were, and hate the thought of being out of focus.
2) Many times you or your subject are moving, meaning you have to continue focusing as they or you move.
3) With the newer cameras, and their advances in autofocus are they not accurate enough, if we do our part and get the subject in the center?
I am not talking about special shots where you will do selective focusing, or where you have the time to really make sure things are spot on. I am talking about ceremony, reception, isle shots etc.
I know the XH-A1 can be in auto focus and you can manually override it at any time.
Maybe I am worrying too much, but with some of my DSLR lenses, they have such a low DOF that If I focus on the nose, the eyes are out of focus, I realize that the video camera does not have that shallow of a DOF and maybe the focusing is not quite so precise.
Joe Simon March 5th, 2008 09:32 AM
I always shoot on Manual. On the XH-A1 I don't like how the instant auto focusing system works, it jumps into focus and doesn't look natural.
I think it also depends in what format you are filming. If you are shooting in 24f it will be best to be in manual, 60i you might be fine in auto.
Denny Kyser March 5th, 2008 09:51 AM
Joe, I agree about the jumping into focus, I believe there is a way to not do this, or to slowly go into focus, but I know as soon as I set it up this way I will see something happening quick and it will take forever to reach focus.
I am practicing on manual focus but still go to auto if I have any questions. Also when using manual after using auto focus you have to remember your in MANUAL.
Oleg Kalyan March 5th, 2008 09:54 AM
Whenever I can I do a manual focusing, that's a must if working with H1 with full manual lens!
John Moon March 5th, 2008 10:06 AM
Most of the time we are in manual mode. This also keeps you more tuned into your camera.
Ethan Cooper March 5th, 2008 10:13 AM
Manual when I can help it, or when I'm shooting rings, churches, things that don't move. I have to go auto when on stedicam and running around, and I'll go auto in extremely fluid situations where I know I can't keep up with manual.
***EDIT**
Forgot to mention that I'll often begin the ceremony in auto for the bridesmaids walking down but if I notice the camera is hunting a bit (usually the case in dark venues) then I'll go manual. Pulling focus down a long aisle when zoomed in and trying to keep a decent framing isn't my strongest skill. I usually sacrifice a goat to the autofocus gods before each ceremony in hopes that it'll behave for those first few minutes.
Matt Bishop March 5th, 2008 01:50 PM
I haven't touched the auto focus button for 3 years. I prefer to never use it because it does keep you on your toes a little more and I have gotten down the skills to follow individuals down the aisle and such while constantly staying focused on them. I had an assistant switch his to auto during a ceremony and it kept trying to readjust whenever the bride or groom moved. It was definitely obvious so that's why I just never use it.
Renton Maclachlan March 5th, 2008 01:59 PM
From a peasant. To date I have not got the hang of manual focus on my cameras so never use it. In the 1 3/4 hour of the wedding I'm editing at the moment, I'm only aware of one patch were one camera did not get the focus right and hunted around for about 5 seconds for it. I just chose another camera for that point.
Further, my wife is on one of the other cameras and doesn't know anything about the camera controls anyway, except for zoom in and out...
Peter Ralph March 5th, 2008 03:13 PM
auto is great for finding focus but always shoot in manual. You will look like a complete doofus if the camera starts hunting.
You don't need to be able to focus manually - that can be tricky on the servo lenses - just switch the AF off once the shot is composed.
With a bright background the AF can be fooled even if the subject is center frame.
Denny Kyser March 5th, 2008 03:38 PM
Been practicing with Manual focus off and on today, gettting a bit easier.
Steven Davis March 5th, 2008 03:56 PM
***EDIT**
You took the words out of my mouth. It is rare that we have focus issues, largely because we are stationary and the ceremonys up to this point have been slow moving events and we use multiple cameras, some that are As for the reception, we still do auto as we switch off cameras etc.
We also use auto for any steadicam work we need to do.
Terry Hulf April 24th, 2008 01:32 AM
sony hd 1000 manual focusing
I am using sony hd 1000, I find it almost impossible to focus manually,is this a common problem, or is it me,if this is normal I would consider upgrading to something else, how much would I have to spend,and what would peoples recomendations for an upgrade be,£3000 price range or would I need to spend more for the privalage of easy manual focussing.
Vito DeFilippo April 24th, 2008 06:02 AM
I'm with Ethan and Steven. I use manual when I can, but for running around after people dancing or whatever, the auto focus works much better than me.
Noa Put April 24th, 2008 11:47 AM
For me it's also a combination of auto/manual; most cases the auto focus works just fine but when I zoom in I go manual and use the one push focus button to correct if necessary. Same when it gets too dark, then it's allways manual with the same one push button to correct.
Dana Salsbury April 25th, 2008 07:37 AM
Manual, unless I'm doing something unusual that doesn't afford me the time to focus.
