Samsung 19in
just grabbed one of these on sale at BestBuy for $399.
HD-grade 1440 x 900 pixel resolution. It has component/DVI input and looks great. for $399 you can't go wrong. http://www.bestbuy.com/site/olspage....=1149208575454 |
I used one of these on a client shoot a month ago with an HVX...it was...OK. I'll probably end up with a Marshall 7" that I can attach to the camera.
I've seen those 7" Marshalls and while they are nice and compact, and good for monitoring color, they are too low res for focus use which is critical with HD. The current Marshall is only 800 × 480 and about 1/3 the size of the samsung < not to mention 5X the price > Marshall has a new model due next month that is 8.4in and 1024 x 768 at close to $4K retail. My suggestion was more focused towards $$ and usability... |
I've read that the 7" marshalls were pixel for pixel on the internal scaling and good enough for focus, (including from various posters). Did you actually see that for yourself? Curious as I'm going to make a purchase.
yes... just IMO of course. I found that with the marshall and a larger higher res lcd hooked up together, that you could dial in perfect focus on the larger
but had to feel/guess the small amount needed for a tight image witht eh marshall.< and it is expected for the size/res > It wouldn't be an issue for SD, but I could not trust it for focus in the field. |
Thanks Brian, this is counter to what I've read, and not sure if from actual users or heresay. Maybe these others were comparing to the usual 250 Hz rez SD stuff out there. Focus is an issue in the field with these HDV cameras, and it's from all the camera's I've rented/tested, the LCD and focus is the weak issue.
