-   The View: Video Display Hardware and Software (https://www.dvinfo.net/forum/view-video-display-hardware-software/)
-   -   Lilliput 7" 669GL-70NP Charger Instructions? (https://www.dvinfo.net/forum/view-video-display-hardware-software/499761-lilliput-7-669gl-70np-charger-instructions.html)
Harry Simpson August 19th, 2011 09:00 AM
I've owned this monitor and 12V 6800mAh Lithium battery for about a year now and lost the one page instructions for charging but it seemed like it said plug in the charger and charge until the red light turns green.....anyone know the correct method? I seem to remember that you turn the battery on while charging it.....Is this correct.
I found the instructions online months ago but have since re-done my OS and lost the link......
Any help greatly appreciated.
Harry
David Dalton August 19th, 2011 03:15 PM
Re: Lilliput 7" 669GL-70NP Charger Instructions?
Harry
I've got the 667GL-70NP. The manual for that model does not mention how to charge the battery, probably because the battery is considered to be an accessory.
I just plug in the charger and wait unitl the light turns green.
David
Harry Simpson August 25th, 2011 08:44 AM
David
Do you turn the battery on while charging.....and somehow I remembered the charging was flipped to what most battery chargers are as in maybe the green indicated it's charging the the red with no green indicates its charged....
David Dalton August 28th, 2011 03:21 AM
Harry
I've checked and I realise that the 669GL is different from the 667GL, in that the 669 has an internal battery while the 667 (my system) uses an external battery.
I've done a quick seach on the web, and the only manual I can find is for the 668GL, which uses an internal (replaceable) battery. There are no charging instructions in that manual.
It may be worthwhile contacting the US distributors.
David
