Monitoring for Colour Correction & Graphics Card
Hi,
This question has probably been asked a thousand and one times, but I'm struggling to find the information I'm looking for. I run a pretty powerful machine with 2x 22" Viewsonic Full 1080p HD Monitors. After being frustrated many times over about how different my videos look on different monitors (although I guess this will never stop happening!) I have been considering buying a broadcast monitor to make colour correction/grading more accurate. I would need to buy second hand, as these things are incredibly expensive - and eBay has thrown up some good results i.e. 20" Sony CRT Monitors w/ SDI for approx £300. Now, I currently shoot SD, but if all goes well, will be shooting HD from March next year - so I don't really want to waste money on sorting out an SD monitoring solution, to then move over to HD, So - my main question is - how do I go about hooking up a broadcast monitor to my computer, for as little money as possible!? I've seen the Matrox cards and a couple of products by AJA but they are very expensive. Is there a cheaper way of doing it, or is it tough luck and it costs what it costs? This then leads me on to my next question, which is what kind of monitor should I look out for and with what connections? HDMI? HD-SDI? Size isn't really an issue, as long as it's no larger than 20" - although I could see a smaller monitor having an advantage for shooting too? Sorry for the long, waffley post! Cheers, Ollie |
In my case I went with the latter, opting to buy a decent monitor (Dell U2410) and the Matrox MX02 mini. This solution is not perfect. Some of the Dell U2410s tend toward a pink hue after as they age. Mine is still quite new and I haven't seen this. And the Matrox box isn't perfect either, but it's been good enough for my needs, and I'd trust it for all but the most stringent of broadcast needs. There's just now way an $800 solution is going to match a $3500 solution. But it's been good enough for me. But if you are thinking you can do this for a couple hundred dollars, you are going to be very disappointed. By the way, I have an SD Broadcast monitor, and I disconnected it in June and haven't looked back. It did a nice job for SD work, but just wasn't what I needed once I went HD. Oh, and by the way, color work is generally done on rather large screens. My 24" is considered terribly small for this work. The common standard is 30" and for film the work is done via projector whenever possible. |
You didn't mention which NLE you use. This will make a difference with the output options available. I use CS5 and now have the ability to output color accurate RGB directly from Premiere. I have the option to use the second HDMI port on my graphics card to do this. Apparently this is the only NLE which offers the ability to do this. Read about it here:
ProVideo Coalition.com: TecnoTur by Allan Tépper Now all that is needed is a pro HD monitor. I would recommend the Sony LUMA series. http://www.bhphotovideo.com/c/product/494605-REG/Sony_LMD2030W_LMD_2030W_20_Professional_LCD.html |
The problem with this, is that Premiere isn't a grading application. Even Color Finesse which is included with AE isn't the most awesome thing out there, though it's pretty good.
So if someone is actually looking to do color grading (and not just basic correction) the Premiere solution isn't going to cut it. |
After Effects with basic color tools is good enough for anybody who knows what they are doing, as long as one is working in 32-bit mode linear. The 'professional' color apps don't make it easier, only faster.
Regarding the matrox, etc. please read my post here on the subjet: http://www.dvinfo.net/forum/view-vid...-matrox-2.html |
Not to hijack the thread, but I was wondering what you guys thought about the Panasonic BT-LH 1710P for this application? I just got one for production but am wondering how it would be for post.
http://www.bhphotovideo.com/c/product/598792-REG/Panasonic_BT_LH1710_BT_LH1710W_17_Widescreen_HD_SD.html mb |
1. Use a powerful dual-head graphics card(Premiere only) 2. Use the Intensity from Blackmagic for @$200. It works with Premiere, After Effects, Final Cut and perhaps other NLE's. Once you get the proper signal out of the computer get a professional monitor which will display the colors accurately, like the one I mentioned. Unfortunately, you're looking at @ $1,000 to start. |
I have this LCD as well and its great except for its scaling. Because its only 1366x768, you will find it somewhat inadequate for 1080p editing. |
Thanks a lot for all of the replies!
As you said, I forgot to mention my NLE. I'm using Adobe Premiere Pro CS5 (I use the whole CS5 Production Premium). I've heard of the Matrox kit before, but it seems quite hard to get hold of in the UK. Brian, you mentioned the following: "Use a powerful dual-head graphics card(Premiere only)" - I currently use a NVIDIA GTX460 which has two DVI outputs (using these for the 2x 22" HD Monitors) and one HDMI port - is this useable for the setup you suggested? Thanks, Ollie |
It should work if you can use it to drive three monitors at a time. My setup only involves two. My suggestion is to connect a test monitor(inexpensive set that can be returned) and see if you can get a signal using extended desktop to it. If not, you may be limited to two. Once you are able to drive the set, playback some test footage to it and make sure it plays back smoothly. Use full HD if possible. Lastly, if you are satisfied with the performance, all that is left is adding the pro monitor.
The Nvidia cards are limited to only 2 outputs at the same time. Your cheapest option for a 3rd monitor is get another nvidia card that can be hacked to work with Premiere's hardware acceleration such as a GT240 with 1GB ram. Then try Premiere's playback function and use the 3rd monitor solely for that.
For QUALITY LCDs, the minimum you should consider is the new NEC for $1000-1100 plus their calibrator or a Spyder or Eyeone (i1) for another $150-200. Furthermore, I believe Nvidia's control panel allows you to select either RGB or YUV output; thus, you would select YUV. To read about the Mini's issues, go here: Matrox MXO2 Mini Calibration Issues : Matrox Video Systems |
I've actually got a spare graphics card, that came with the PC (it's a custom spec PC) which is a NVIDIA 9800GT which has; 1x S-Video, 1x HDMI & 1x DVI connections and has 512mb DDR3 RAM.
Is this up to the job, or would you strongly suggest something with 1GB RAM? With regards to the 'Spyder' interface, I guess It's a device that gives you the calibration tools.. I assume it includes the 'blue' mode? |
Now that I think about it, that card might actually work. I say this because another person here, Tim Kolb, has a certified card for hardware acceleration and then a 2nd card (not certified) connected to 2 LCDs for more screen room. What you should do is this: have the GTX as your main card with the timeline and source window on 1 LCD, the Program/Playback window on the 2nd LCD and your other windows on the 3rd LCD connected to the 9800. In the display configuration, you will have 3 monitors to setup. #1 must be connected to the GTX because that will be your main LCD for Windows.
Essentially, any video playback must be done thru the GTX. And about the Spyder and calibration: as far as I know, it does not do Blue only. The Spyder and i1 are devices that hang over the front of the monitor and calibrate to a specified Gamma (2.2) and White Point (6500). With real VIDEO monitors such as the higher-end NEC, Eizo and others, these calibration devices interface with special software from NEC or Eizo in order to calibrate to specific COLOR SPACES such as Rec 709 (HD video), Rec 601 (SD video) and DCI (film). If you are delivering your video to SD broadcast, then you would have your monitor calibrated to Rec 601, for example. There is a misconception that calibrating a monitor with the Matrox software for POST production (ie, color correction, grading, finishing...) is the proper method. Calibrating a monitor by using Bars is meant for Production purposes. Calibrating a monitor to specific color spaces is meant for Post production., which is why my Eizo CG243W has a few calibrated settings, one for SD broadcast-Rec 601, one for HD broadcast & HD web-Rec 709 and one for film-DCI. Furthermore, my Panasonic BT-LH1710W with HD-SDI is connected to my EX3 for production; so, it is calibrated with Bars being output from the camera. |
Thanks for that Steve.
So if I was to use both of my cards - it'd be done in the following configuration: GTX460 - Main LCD display on DVI & program/playback LCD display on HDMI. 9800GT - Secondary LCD display for more windows. Now that I've got this sorted (I think!), all I'd need to sort out is what sort of monitor I should be looking for, for use as the program/playback display and what tools I'd need to calibrate it for post production purposes. I apologise for all the questions, I'm new to this - but very keen to learn! |
Thanks |
Something like this worth considering for edit/CC?
http://www.bhphotovideo.com/c/product/706682-REG/Eizo_S2243WH_BK_FlexScan_S2243WH_BK_22_LCD.html |
Definitely stay away from the Sony LCDs as they have poor image quality for their price.
That Eizo is nice but cannot be hardware calibrated to specific color spaces. http://www.bhphotovideo.com/c/product/676418-REG/NEC_PA241W_BK_MultiSync_PA241W_BK_24_Widescreen.htmlNEC Display Solutions PA241W-BK This NEC can be hardware calibrated to specific color spaces and is quite comparable to my $2300 Eizo. Its $800 at B&H for the monitor only and $1240 with calibration device. I don't see why NEC is charging so much just for their calibration device when an i1 is only $150. When you add up a Matrox Mini at $450 and a decent 24" (Dell U2410) at $550, this NEC is a great deal AND provides SUPERIOR image quality. |
| All times are GMT -6. The time now is 01:51 AM. |
