What's the differences in the Noga Cinearms?
I'm attaching a Marshall LCD70XP to my rig. I see Noga DG1108ca and DF1108ca "Hold It" Cinearms. There's also NF 6145CA Cinearms. The photos are all similar and prices vary. The Marshall recommended DG1108CA is out of stock pretty much everywhere except the high markup places (supply/demand I suppose).
Anyway, does anyone know the difference between these mounts? Any recommended ones or NOT recommended ones? What about alternatives to Noga (I see Delmount and Ikan). TIA |
I have a noga arm and it is fantastic. I have a pair of redrock arms that look basically identical but are horrible to use. I mean, I wont use them on anything i care about because they are so jerky to use and can unscrew and fall apart as you work them. I wont be buying a non-noga arm again. I wrote one of my epic ramble review of the redrock here: http://www.dvinfo.net/forum/view-vid...rm-report.html The variables you want to consider with the noga arm are: 1. the length. They make a few lengths. 2. the screw sizes on the end. Some are 1/4-20 on both ends, some are 1/4-20 on one and 3/8 on the other. You need the one that works with whatever you are screwing to. I bought the one with 1/4 on both ends, but kinda wish i'd got 3/8 on one end for more rugged mounting. 3. The quick release plates. If you dont mind threading and unthreading each time, this isn't critical. If you do, consider the nogas with the quick releases. They are expensive, but really compact and sturdy. 4. The hot shoe mount. I don't understand how this is supposed to work. The giant tube thing is awkward, is threaded on one side with 1/4 and the other with 3/8 but comes with the 1/4+1/4 arms. and worse is I don't get how its supposed to be used. Why is it so giant? When is that an advantage?. On the other hand, i use the "shoe" bolt with other finger nuts to connect a tiny ball head to my shoe for the dp6, which works great. I'm sure there is a cheaper solution that doesn't include buying and disposing of the giant tube thing. 5. The t-bracket mounting plate. I can't picture why you'd need it... if you have a thread to mount the plate into, why not screw the arm into that? I might be missing something there... perhaps so you can mount multiple arms into one hole? Or perhaps to mount a 3/8 into a 1/4 hole? dunno. Don't know if that helps or clouds the decision, but thats my feedback. Lunch is over, back to the shoot! |
I like my Zacuto arm.
I went with the Ikan from B&H and it works great on my EX1R
