Xbox, PS3, HDMI, image recording
I'm trying to sort out a workflow to screen capture a gaming competition in October. We will be using 2 Xbox 360s for the actual competition. Alternatively, we will be using a PS3, Wii and maybe an old school NES for downtime game play.
Now I'm trying to find a device(s) to allow me to record these 3 screens either individually or together. I'm trying to avoid latency and I'd like to be able to capture them using something other than a computer. Both audio and video are important for the final product. The HD gaming is more important than the older platforms. Any suggestions for workflows and products? Thank's in advance. |
If you're not keen on a computer for capture, a simple XDCAM EX deck (PMW-EX30) with HD-SDI in combined with a HDMI-HD-SDI converter and a HDMI splitter (so that the TV gets the feed and the recorder gets the feed) will work. Don't get confused by the HDMI port already on the back of the EX30, it's an output only, not an input. And using that port will introduce lag.
If you're trying to capture from a PS3, it's harder since the HDMI is protected. You're going to have to play in SD (480i) for your PS3. You must take the monitor out of the TV and pass it through a AV-DV device (like a camcorder with analog video in and DV out) in order to get it to the XDCAM EX deck. XDCAM EX deck: Sony Product Detail Page - PMWEX30 Unfortunately, there is no legal way to get HDMI from the PS3 without breaking an anti-circumvention law. This is the best workflow I can recommend. |
How about HD component analogue instead?
Duncan,
That would be a great option. What workflow would you suggest? |
I don't know any specific kit which can record three streams, or one etc. etc. I'm only suggesting component as an alternative to HDMI as the copy protection is not an issue.
I think your solution will involve several bits of kit, recorders, convertors etc. Without an idea of budget you might not get much advice that's of any help. You need to display and maybe mix between several HD source and record them, that's a tall order if you're on a budget. It sounds like you'll need a scaler switcher, the kind of kit used at conferences, adding recording is another layer of complexity and expense. I directed a conference recently using an OctoVueFX. This will take HD analogue sources and output to an HD monitor/projector, but they cost loads to hire, and only cover basic cuts and mixes. If you want multiple images on one screen your talking lots of money, thousands a day. However if you worked in SD, you could use S-VIDEO and hire a wider range of DVE's for much less cost, and recording options would be so much easier. |
Duncan,
The plan is to capture the footage for later syncing. We seem to run into a delay when the footage from the system runs into something else before it comes out to the TV. This would be maddening for a gamer because the controls need to be fluid and accurately responsive. Budget is a less than 500.00 dollars. So far we've seen this: Blackmagic Design: Intensity Seems like an ok solution. We've also considered just splitting the signal and taking it straight into a computer. Thoughts? |
