Good monitor?
I found some pretty good deals on used Sony GVM-1311Q 14" color monitors. Video editing is just a hobby for me so I'd rather not lay down a lot of cash for a top quality monitor, but I would like to use something that can be calibrated better then my TV set. Does anyone have any experience with this monitor? Any other suggestions on an inexpensive monitor?
thanks, Barry |
I haven't actually used one, so I can't speak from experience. Looking at the monitor's manual, though, I can tell you that it doesn't have a blue-only switch that would make it easier to calibrate. You can look at the manual here: http://www.docs.sony.com/release/GVM1311Q.PDF
You can always use a deep blue filter to calibrate your monitor, but having a blue only switch makes it easier. That's my thoughts, anyway. Maybe other, more knowledgable people will have some advice for you as well. Christopher |
Christopher |
Even though a lot of folks are down on ebay, I still search it when I need something. I found a 20" NEC 2000 video monitor for like $150. It has a blue switch, S-vid in and out, and more. It was well used, but in great working condition.
Thanks for the help everyone. I hadn't realized that monitor didn't have a blue-only mode and that is one of the features I am looking for.
take care, Barry |
I purchased a Sony broadcast monitor off of ebay. It was damaged in shipping, but that was the shipper's fault. So we found another seller on ebay selling the exact same model, but in our city, so we went and picked it up at their location ourselves. Another advantage was that we were able to examine it before we bought it.
Christopher |
I finally found the right monitor for me. It didn't have a blue-only mode but the price was too good to pass up ($70 for a 14" JVC monitor in good working order). My only question now is if these are the right kind of blue gels to get:
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=31913&is=REG http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=getItemDetail&Q=&sku=31911&is=REG&si=feat#goto_itemInfo Should I get the larger ones or just use a couple of the smaller ones to adjust the monitor settings? |
Any thoughts?
I use a number 47 blue filter. You could probably use a number 80 or 81 filter also. B & H would have these. A small size like 49mm would be fine and relatively inexpensive and very durable.
thanks Jeff.
One last question: will any kind of filter do, or does it have to be specifically made for tricolor separation? I found #80 Primary Blue and #81 Urban Blue lighting gel for substantially less money than the #47 tricolor separation filter at B&H and was wondering if those would be alright.
thanks again, Barry |
From my experience the R80 gel is probably OK, but you will need to double or triple it up to get it dense enough. It sounds like that #47 filter might be a good solution however if it really only lets through primary blue, plus it would hold up for a long time as Jeff suggests.
