-   The View: Video Display Hardware and Software (https://www.dvinfo.net/forum/view-video-display-hardware-software/)
-   -   IS 'blue check' that important on a prod. monitor for color correction? (https://www.dvinfo.net/forum/view-video-display-hardware-software/24619-blue-check-important-prod-monitor-color-correction.html)
Jeff Johnson April 15th, 2004 08:54 AM
Hi-
Just wondering looking at all the diff monitors out there. JVC has some high res monitors but don't apppear to have the blue check feature.
I already have a Samsung 'client monitor' TV, but I need something that will give me an accurate color representation for local spots as the samsung is all over the place.
Even if the JVC don't have the blue check, is it still better than the Samsung as far as being 'true colors'
Thanks-
Jeff
Rob Lohman April 15th, 2004 09:04 AM
http://www.dvinfo.net/conf/showthrea...threadid=24178
Please try to use the search. A search on "blue check" resulted
in that thread on the 5th hit (would've been the 4th without
your thread) that has the following title "What are underscan &
bluecheck" which will answer at least part of your question.
Jeff Johnson April 15th, 2004 09:24 AM
I did the search and I saw that thread. I got the jist of what blue check was just wanted some real world opinions on whether it was 'imperative' that blue check be on any monitor you were trying to get a reasonably accurate color read from.
If blue check is most accurate, is a production monitor that does not have it at least better than a samung?
Thanks for any input.
Jeff
Mike Rehmus April 15th, 2004 11:41 AM
You can perform the same adjustment with or without the Blue-gun-only button on a monitor. You need a fairly deep blue filter and a copy of a monitor adjustment proceedure you can get on VideoUniversity IIRC.
The results are the same however the button is quicker and simpler (you don't have to hold the filter over your eyes when you adjust).
I use both methods. On a camera with a color LCD panel or Viewfinder, you almost have to use a blue filter as they don't have a blug-gun-only button.
Jeff Johnson April 15th, 2004 11:50 AM
Thanks for the tip Mike, at the risk of sounding completely remedial, the blue check is just a one time adjustment or fairly periodic?
Jeff
Mike Rehmus April 15th, 2004 07:17 PM
Kinda depends on how stable your monitor is.
The LCD will probably be reasonably stable unless you adjust brightness which does change the calibration.
Most TV stations used to check at least once every 8 hours by someone who had a 'golden' eye. Don't know what they do now.
I only do it when I think about it which isn't too often. But then the little 14" JVC broadcast monitor I have is quite stable.
