-   The View: Video Display Hardware and Software (https://www.dvinfo.net/forum/view-video-display-hardware-software/)
-   -   Monitor? (https://www.dvinfo.net/forum/view-video-display-hardware-software/19848-monitor.html)
Robert Jackson January 15th, 2004 04:34 AM
Monitor?
People here have talked about how bad the LCD system on the HD10 is, so what are you using for a field monitor? I assume most people are using some kind of 8" or 9" CRT, but how do you get the video into the monitor? There's no SDI output on the HD10, right? Can it even output HD while shooting? I seem to recall that it couldn't. Most small monitors anymore are BNC or SDI. I'm just wondering what has been used that worked well with the HD10.
Sorry about all the questions, but I really need to sort this out and finish up a budget.
Troy Lamont January 15th, 2004 10:42 AM
Robert,
That question has been addressed a couple of times since I've been browsing this site with no real solution.
Some people have just been using a standard NTSC monitor via component and viewing a widescreen 480p image.
Here's my take, when I posted my results on connecting this camera to a TV that has firewire input (see here), I discovered that you could monitor in HD via firewire on a Mits rear projection set!
The problem now is finding a monitor that's small enough that has a firewire input. I'm still looking myself and will report back if anything surfaces.
On the other hand I had suggested using a laptop with firewire input, but the software that comes with the camera doesn't do any monitoring. I haven't tried it with any other software because I don't have any pro level software like Premiere Pro or Vegas.
I have Ulead Video Studio but the preview window is small and can't be resized. I'll give it a shot to see what happens.
Ideally a 10" LCD/CRT with firewire would be excellent. There firewire to component convertor/adaptors, but most of them cost almost as much if not more than the camera itself. You can check here for options. Actually in reviewing that site again, it looks like there's an $599 option that might be worth looking into.
I'll email the manufacturer to see if it's compatible with MPEG2 TS and I'll report back.
Troy
Ken Hodson January 15th, 2004 11:40 AM
This is what we are getting
http://www.bhphotovideo.com/bnh/cont...=127285&is=REG
It will double as a studio/field monitor for us. In the studio it will be connected to the Parhelia card for RT TV out 16x9.
Ken
James Ball January 18th, 2004 07:05 PM
LCD Monitor with firewire HD input.
It's HD Unclear about what would happen with a higher resolution signal. 15" and is rack mountable.
The DVM-150X Color LCD DV Monitor directly accepts an IEEE1394 Firewire Digital Video signal....
http://www.markertek.com/MTStore/product.CFM?BaseItem=DVM%2D150X
MFG data sheet:
http://www.tvone.com/pdf/SpecSheet-DVM150X.pdf
Troy Lamont January 19th, 2004 11:14 AM
I got a response back on the adapters and they are for DV only. They are also in the process of doing a 7" LCD with firewire in but it will be DV only also.
Robert,
That product is DV only also and I would bet that it wouldn't be able to handle the MPEG2 stream from the HD1/HD10.
Troy
Troy Lamont January 19th, 2004 03:41 PM
Sony Pro offers a very expensive 17" solution to anyone with deep pockets. You can check it out here for $4K
Here's the pic link.
Still searching...
Troy
James Ball January 19th, 2004 08:38 PM
my brain slipped
right DV not HD
still for $1200.
Did they say what would happen when you presented it with the HD signal?
Troy Lamont January 20th, 2004 08:58 AM
They didn't, but I would only imagine that nothing would happen. I've tried to get an HD signal to a DVD recorder with DV only in and nothing happens.
As I posted in another thread, I've also tried to get HD->DV downconversion but it didn't work....
Troy
Ken Hodson January 20th, 2004 01:58 PM
I just realised that the field monitor I mentioned, while it will work fine in the field (S-video out 16x9) as the cam only outputs SD via Y/C or composite. I will need a true HD monitor for my RT TV-out previews from our Parhelia card. Correct?
Ken
Troy Lamont January 20th, 2004 02:07 PM
That's correct. Either one with component or firewire input (if firewire it has to be MPEG2 compatible). Preferably one with 720p capabilities so you won't have to up-rez your footage.
Troy
