Field Monitor Stand for JVC TM-910SU
Can anyone point me in the right direction? I am searching for a stand to use in the field for the above 9" monitor.... so I don't have to crouch low to the ground to view my shots... a stand that is adjustable (heightwise), is stable to where it won't topple is ideally what I'm searching for. Thanks to all and happy holidays to one and all.
Pepi Singh Khara |
Check my review of the Dolphin Rack.
Another solution is to buy a PA speaker stand that comes with a detachable flat plate. I use them to hold microphone anti-echo boxes and to hold a monitor. Just need a piece of plywood with holes where the feet go to attache to the plate and a velcro strap to hold the monitor on.
The trick is to buy one the speaker stands that has one adjustable foot so you can handle unlevel ground. Another solution is to buy the nylon shelf that Bogen sells for use on tripods. It hangs between the legs and from them and should be strong enough to hold a monitor. I am saying this from memory as I haven't actually tried this. |
Thanks guys!
