CRT for Grading?
I've read in many places that LCD's are just now starting to catch up with CRT's in terms of picture quality for grading.
So I'm wondering, "Why not get a CRT (new or used) for grading?" I wouldn't use it for all color correction, but for the fine tuning, I could sit in front of a CRT for a few hours if need be. Any suggestions of a potential CRT to use? Thanks much as always. |
For SD work, I'd get a broadcast monitor like the ones from JVC, Sony (discontinued), Ikegami, Panasonic (discontinued). They will show interlacing correctly and have good color reproduction.
Quality generally correlates with price. Look for blue gun and SMPTE C phosphors (SMPTE C if you are in a NTSC country other than Japan, EBU for PAL countries). Not all of the entry-level monitors have SMPTE C phosphors but their color reproduction should be reasonably close. 2- Used CRTs might have subtle image imperfections. So be careful buying them... I'd highly recommend you look at the image before buying. (e.g. would you buy used shoes without examining them?) CRTs get worse with use. 3- What's your price range? What are your needs? Do you need HD too? |
Glenn,
Thanks very much for the reply. Yes I will definitely need HD. I will be trying to do as much finishing as possible myself, using either SCRATCH or Avid's DS Assist Station. The documentary I'm working on has the possibility of theatrical release (don't they all, LOL) so I need to grade for that as well broadcast. Essentially, I'd like to do as much of the finishing as I can myself. I've read accounts of people using DS Assist or SCRATCH to even make their own DI's. This has me very intrigued. |
I'm using JVC:
DT-V1910CG 19" HD multi-standard Colour Monitor 1000 TV lines resolution on Natural-Flat screen Takes all progressive/interlace I/Ps from SD to HD Auto input selection of HD SDI and SDI Optional input cards for component/RGB/SDI 16:9/4:3 switchable with 14:9/13:9 area marking Comprehensive front panel & CPU menu control Built-in audio monitoring Not sure if they still make the 19" version, but sure there is a 17". The results are fab, real monitoring, correct field order issues, makes flat panels look awful, and has composite, S Vid, component SD and HD inputs as well as SDI if you want, basically, you order the spec you need, so it's cheaper than a rig with everything on board. Paul |
It might be possible that you can use a video Rec. 709 workflow for filmout (and then they try to make the filmout look like what one would see on a Rec. 709 monitor)... but I don't know. 2- I've put this reply back into this thread... it's easier to keep track of things with one topic per thread. |
| All times are GMT -6. The time now is 08:22 PM. |
