Waveform and in Field Vectorscope?
I'm interested in checking waveforms and a vectorscope in the field. My idea is to use a DSC color chip and grey scale charts to check the waveforms and vectors before shooting.
Is anyone doing this and have monitor recommendations? I'm considering having a computer on location, onto which I can load with Vegas &/or Avid AXP/MC. Thanks much! |
My boss uses a Leader 5750 I believe in the field and we use it for color correction back in our suites when he isn't using it. It monitors audio also.
That's one expensive monitor, but I'm sure worth it.
I'm considering having a computer on location on which I could run Vegas. (I'd also be using the computer for on location capturing.) Vegas has scopes and waveform. This should work okay, right? |
I don't believe those scopes are real-time. DVRack / Onlocation is.
2- Personally, I don't really believe in using scopes during production (unless you need to do something like camera matching). If you learn your gear, you're just not really going to need it. Shoot a test with multiple bracketed exposures, color correct/grade it, and see what exposure is the ideal exposure. Figure out how that corresponds to what you see on the camera viewfinder/LCD or on a broadcast monitor. |
Glenn, as for your first point, I was thinking of recording and actually capturing some footage into Vegas while on location. That should work.
For point two, I've heard that lattitude is not uniform across F stops. So with same fps and shutter speed but different iris openings, some exposures have more lattitude while others less. And for some compositions you actually want less camera lattitude (not more). The idea being if less lattitude is in the composition, you try to shoot using an exposure with less lattitude. This way color bits aren't being wasted on intensities that are outside of the range of what's being recorded. Is that accurate? (I'm not saying that means I need on location waveform and vector scopes.) Thanks much. |
In any case I think you'd learn a lot from doing a test. Bracket exposures, color correct/grade your footage, see what you like best. |
I will do a test. Promise :). Thanks for your help. |
| All times are GMT -6. The time now is 01:41 AM. |
