Sorenson Squeeze Question
Hi everyone:
On pins and needles awaiting the judging of this round of great films? Well, to bide your time during these suspenseful moments I have a Sorenson Squeeze question and wonder if any of you have run into this. Shortly after UWOL 7, I purchased my first and only HD camera. Looking ahead to UWOL 8, I've attempted to go through the motions of shooting, downloading onto the Mac, processing and finally squeezing a full definition 1920 x 1080 clip to the UWOL challenge specs. I've been successful in coming up with a squeezed HD clip but only as a full download. If I do all the same settings, but specify the output to streaming video, Sorenson processes the clip, completes successfully but upon playback it says that it is unable to open/play because it's an invalid file. Just curious if you've seen this before. I have Sorenson Squeeze v 4.5. Browsing the knowledge base on the Sorenson web site hasn't revealed much about this. Thanks for your insights. O.K., you can go back to the suspenseful waiting now! Cat |
What are you using for an editor Cat?
Hi Kevin:
Thanks for the look. I mostly work in Adobe After Effects, but also in FCP. I know you work in FCP and Compressor. I have discovered that I have more options to tweak in Sorenson Squeeze than in Compressor, but perhaps I am wrong on this? I've only looked at and worked with Compressor a few times. All the best, Cat |
Anyway, you can always find the squeezed file, from outside Sorenson, and then open it in the software specified for that QT-file Hope you understand what I mean? I'm sitting up in the mountain at the musk-ox right now, so I don't have my edit computer in front of me! |
Wow Per!
Thanks for the feedback, even out in the field with Musk Ox stalking around! Thanks for the tip, I'll look into it. Strange thing about the Mac though... you can't find the squeezed file anywhere on the disk! Even with searches it doesn't see it. So it doesn't let you get at it to do anything with it. Keep the ideas coming, and I'll keep trying new things. Thanks, Cat |
Catherine,
I'm using both After Effects 7 and Squeeze 4.5 like you do. But I'm only on pc, not mac. Maybe I can help? (Sent you an email) |
| All times are GMT -6. The time now is 04:22 AM. |
