-   Under Water, Over Land (https://www.dvinfo.net/forum/under-water-over-land/)
-   -   Black Grouse Lek (https://www.dvinfo.net/forum/under-water-over-land/92152-black-grouse-lek.html)
Rick A. Phillips April 24th, 2007 02:11 PM
Originally Posted by Per Johan Naesje (Post 666472)
Rick, sorry to hear that you're not able to connect to my site. The HTML-code this site is build on is plain:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
There are some javascript in it but it should not cause any problems.
What kind of webbrowser do you use? I might do some test of different browsers myself if this is a common problem!
I've tried IE6 and Firefox and always get the same message with both. I just don't think it is anything on your end...otherwise more people would be having the same problem. I haven't seen anyone else post that they had a problem connecting to your site. I'm waiting for a response from my ISP to see what they have to say. Don't worry about this...you just concentrate on getting more great video! Look forward to seeing your entry for UWOL #3.
Rick
Rick A. Phillips April 25th, 2007 06:51 AM
Per,
Someone was kind enough to put the clip up on their server and I snatched it off a few minutes ago. Interesting behavior and beautiful, clear footage. I especially liked the condensation coming out of the birds mouth as it called. Hope you have continuing good luck as spring progresses and looking forward to another great UWOL Challenge entry.
Looking forward to some grouse footage from Dale as soon as he gets his camera back. Hope all goes well with those repairs.
Rick
Leon Lorenz April 26th, 2007 08:27 AM
Per,
I was able to listen to the audio file that you sent, very interesting. God's creation is truly amazing and a lifetime of learning is only scratching the surface.
Best,
Leon Lorenz
www.wildlifevideos.ca
