12 Months at Arsahamomaque Preserve
Arshamomaque Preserve is located in Southold, Long Island. The video documents the passage of the months from a single point of view.
Re: 12 Months at Arsahamomaque Preserve
Very clever project Conrad, with a nice matching music track.
One good edit can make your day, there are people working behind desks in the city who’ll never experience anything like that. Cheers. |
Good job Conrad!
Very good Conrad, enjoyed watching. As an aside how did you go about setting your co-ordinates so the camera was framed in the same place each time or were the clips from a permanent mounted camera?
The images were made from an observation tower overlooking the pond. I penciled in a spot where the camera was located on a window frame. I also printed a picture of the first shot, noted the focal length, and tried to frame the picture to the same boundaries. Then to make sure, I blew up the images in Premiere Pro to 120 %, first put subsequent images on Track 2 over the first image, set the subsequent image to 50% opacity, and lined the images up. I then moved the subsequent images back to track 1. Finally, because, even with care, they were not always framed exactly the same, I trimmed the shots back to 100%. In some of the first images there was a slight (hopefully hardly noticeable) parallax error because I was not quite careful enough.
Hi Conrad, many thanks for taking the time to post the method yuo used to film the timelapse. Thank you, much appreciated
Cheers. |
