Long-billed Curlew, EX3
I am still trying to improve my technique and would be grateful for constructive critiques. I am shooting with an EX3, Nikkor 70-200 f2.8 lens, -3 gain, shutter @ 180 degrees, 1080p 30fps. I have recently switched from Cine4 to Cine1 settings. I processed this clip with Avid Liquid 7 (increased saturation and applied unsharp mask).
I am particularly interested in comments about framing, panning technique, colors, post-processing and sharpness. YouTube - Long billed Curlew Thanks! Jerry Merrell |
2 comments I'd make: get a better tripod, and be good to grade the pictures as they look very washed out (no doubt due to the Cine settings - these are designed to make flat pictures containing as much dynamic range as possible for you to work on afterwards).
Also try some slightly higher frame rates - this often makes small bird movement look more natural and takes the edge of some of the camera movement. Cheers, Steve |
Steve, Thanks for the comments. I will experiment with grading the pictures.
I was recording at 30 fps. Are you recommending overcranking and playing back at 30 fps or shooting at 60i? Jerry |
If you're playing back at 30P try shooting maybe 40 or 50 fps, it's a funny thing but animal movement often looks a lot nicer (and actually more natural) when slowed a bit. You'd probably be surprised how much TV nature footage is off-speed without people even knowing.
I'm no editor so don't know the ins and outs of grading but in essence you're trying to put contrast back into the flattened shots, so deepen the blacks and brighten the whites. Steve |
Steve,
Here is the reprocessed clip. Although I am comfortable with digital SLR RAW files, color grading video is new to me. I adjusted the RGB histograms individually to darken blacks, enhance the highlights and add more contrast. YouTube - Long-billed Curlew - reprocessed Thanks for the comments. I will experiment with overcranking and start shopping for a better tripod. Jerry |
You are definitely moving in the right direction with regards to grading.
When framing shots, make sure you always consider the rule of thirds. You did well to place the curlew toward the right third of the frame initially, but as the shot progresses the shift toward centered framing leaves something to be desired. It is sometimes difficult, especially when just starting out, to avoid centering subjects during pans, but with practice the rule of thirds will become more second nature and you won't even need to think about it (I also think that you will find it easier to focus on framing once you are no longer struggling with an insufficient tripod). I can see where this would be a unique challenge for someone transitioning from still photography to video since maintaining good framing while both the camera and subject are moving can be quite difficult. Keep up the good work! |
Hi
I see no problems in framing the bird - the air in the picture are in front of it, as it is walking - when it stops and turns you center it - now you cannot tell which way it will walk - if it will? Only problem, as I see, is the stative that is not smooth enough - it could be because of a cheap stative or wind on the camera or yourself when moving - sometimes I grab the head of the stative instead of the pin sticking out to make a smooth pan.... |
Hi Jerry,
The repost looks lovely to me! As to the slight vibrations you get I do the following which really helps: To avoid the vibrations caused by the wind I always use a hide which blocks the wind - extremely useful. In order to avoid vibrations caused by touching the camera/handle/tripod I attach a rubber band to the handle and only touch it. Also very effective. Keep it up mate, Regards, Ofer |
Cheers, Ofer Ofer Levy Photography |
Thank you for all the helpful comments.
Jerry |
Nice Jerry.
The old advice about tripods is still true, buy the most expensive you can afford and the heaviest you can carry. My favourites for the EX3 would be Ronford 2004 or O'Connor 1030, but I know a lot of guys (like Ofer) go for the Millers with a lot of success. If funds are tight I'd always go for an old Sachtler (like Video 18 II or Video 20 II) rather than a brand new Manfrotto or the like. Steve |
Gerry,
I think the shot is lovely, particularly the improved one. The focus seems to soft to me. Was it shot in DV or HD? |
Steve, thanks for the tripod recommendations.
Dale, the clip was shot in HD (1080p). |
| All times are GMT -6. The time now is 08:06 AM. |
