Min height for tripod ??
Hey there I was just wondering whats a good minimum height for a tripod set up?? for the A1 I'm looking into the libec 22 at 59" or the bogen 351mvb2 with the 503 head. I know the 503 is a better head but some have said that the A1 is too light for that set up has anybody experienced problems with it?
Moved from Canon XH to Tripod Sticks & Heads.
If you're not buying a double extension tripod or short legs, a good minimum for a single extension tripod is one that allows you to shoot just below the eye line of someone sitting in a chair.
very helpful thank you
If you are looking for a really nice tripod at a great price, I would suggest the Bogen 525MV 75mm or the 515MV 100mm (which is what I have.) It goes down to 12.5", which has reduced my need for a high hand on many ENG type shoots, and up to 61.5"--high enough for most situations that don't call for a ladder.
They both support upto 33 lbs, but are still fairly light. Even on the slowest pan setting on my Sachtler Video 18 I don't see any giveing/twisting in the legs. I would suggest a two stage tripod though. It it much easier to store/carry shorter sticks! Matthew Rogers |
In Chris's other post he mentions that he has a total budget of under $500 for the whole shebang. |
Shop shop shop. Key advice! That's how I got a very nice Sachtler Video 18 head for $800. Matthew |
very versatile Tripod setup
After trying many different combinations from Cartoni, Gitzo and Manfrotto, I have settled on a combination that I believe to be the best blend of versatility and economy.
I like it so much I bought a second one for my new camera. A Bogen/Manfrotto 3046 tripod $230 at B&H Bogen 503 fluid head $224 -B&H and the addition of a Bogen Compact leveling ball head $74 for rapid leveling with the flip of a lever. The tripod is a double tube main section with a built in spreader and a single tube second section. This is fine for most shooting using the main section for sitting subjects and extending the second section for standing subjects, landscapes or action. The geared center column makes it easy to do small height adjustments. The 3rd section and geared column give you a total height of 9ft. YES, 9 (nine) feet total height. this gives you a great range for shooting over the heads of a crowd or a dramatic down angle in a narrative shoot. This combination is rock stable up to 6ft or so and only slightly less so fully extended. It sets up and levels quickly and weighs about 14 pounds total. I have thrown it with the camera attached over my shouder and followed horses and riders across hills while shooting a cattle roundup. I wouldn't want to do that all day, but I'm trying to say it's light enough to reposition quickly while still set up. You can't beat the price for the quality and vesatility. |
finally
I think you may have finally found a system that I can use. This wasn't my thread, but thanks for the answer as I think this is exactly what I am looking for.
jason |
3502 Leveling Unit?
Edward,
I was interested in the 3502 leveling unit you referred to, for quick leveling at the touch of a lever.... I read the description provided at B & H, and it mentions it is for tripods WITHOUT spirit levels built in. But the 503 and 3046 descriptions, respectively, mention they each have the spirit levels built-in. So, what is the advantage of this $75.00 unit with your tripod/head setup? Does it provide the element of reduced time required to level out the rig? Curious, since I have the exact same tripod and head... John Reilly |
Hi there
Having used the Manfrotto 351MV/501 combination for a couple of years, I've just got a Libec LS38... So far really impressed.. more compact, better head, lighter...Good value tripod for the money... Regards Gareth |
| All times are GMT -6. The time now is 01:21 AM. |
