Gitzo 1380 springs
Do the 6 springs come with this head or do you have to buy ala carte?
Also any preference for Gitzo or Miller carbon fibre 75mm bowl legs? Miller is rated up to 44lbs load. Gitzo only 26.50lbs. How is leg action? thanks, chris |
In "most" cases the springs are included with the head, but it would be wise to double-check with your particular dealer.
I, however, cannot speak about the CF legs. I use the very heavy 3181s for my rig. Tim |
Personally, I'm leaning towards Gitzo because I'd like to save the pound in weight, but there are obviously several trade-offs to consider. Not sure about the springs - I thought you had to buy the head with a specific spring, and optional springs cost $20. or so. |
